AFD domains asking for revalidation though it was already done 2 years back
Nikhil Mamillapalli 25 Reputation points Microsoft Employee
2026-05-19T10:44:15.13+00:00
PII
for this resource there are three domains already validated long back, and now recently it showed to renew the azure managed certificates, and usually azure used to take care of renewal of azure certs, but today all of a sudden we are seeing to revalidate the domains, why this was happened?
Azure Front Door
Azure Front Door
An Azure service that provides a cloud content delivery network with threat protection.
Ravi Varma Mudduluru 12,625 Reputation points Microsoft External Staff Moderator
2026-05-29T16:42:33.9766667+00:00
Hello @Nikhil Mamillapalli ,
Thank you for reaching out to Microsoft Q&A.
As previously discussed, the backend team cleared the struck renewal operation. Now, the domain validation status changed from “Timeout” to “Approved,” and the issue was resolved.
1 additional answer
  1. Alex Burlachenko 25,290 Reputation points MVP Volunteer Moderator
    2026-05-20T09:26:06.2+00:00
    hi Nikhil Mamillapalli & thanks for join me here at Q&A portal,
    сonfig is probably fine, test new name/RG/region/SKU, then escalate with correlation ID if portal also fails, if it fails from both Terraform and portal, this is almost certainly not Terraform. OperationFailed + “conflict” during create usually means the Managed Redis resource provider hit a backend conflict, capacity issue, stale name/resource state, or regional/SKU provisioning problem. Azure Managed Redis docs also say the service can enter Failed state when a management operation fails, so “terminal failed” is a real provisioning state, not just UI noise. First things to try use a brand-new name, brand-new resource group, different region, and smaller/different SKU. If that works, original region/SKU/name path is the issue. Also avoid preview tiers unless needed, because some Managed Redis tiers are still public preview, especially large memory tiers and Flash tiers. Check Activity Log for the failed deployment and copy the correlation ID, because the portal error is too generic. If multiple regions SKUs fail even from portal, open Azure Support under Azure Managed Redis / Cache for Redis and ask them to check backend provisioning conflict for ur subscription.
    rgds,
    Alex
    If my answer was helpful pls mark it and additional thx if u follow me at Q&A portal
