Build 26300.8493 out to Dev Channel
CrazyKats 19,595 Reputation points Volunteer Moderator
2026-05-15T19:59:49.9966667+00:00
    2026-05-15T20:00:09.9766667+00:00
    Build 26300.8493 is an Experimental channel (formerly Dev Channel) Windows 11 Insider Preview build. Experimental channel builds are early, actively developed builds that can be unstable, may ship with limited documentation, and features in them can change, be removed, or never reach general release.
    To see all current Insider builds and which channel they belong to, use Flight Hub. For general guidance on Experimental channel behavior and expectations, refer to the Experimental and Experimental (26H1) channel notes.
