how do i sign-up for excel's beta channel?
James Tobin 25 Reputation points
2026-05-12T12:49:20.8466667+00:00
how do i sign-up for excel's beta channel? does it require a particular subscription?
Microsoft 365 Insider | Excel | Windows
Marcin Policht 107K Reputation points MVP Volunteer Moderator
2026-05-12T13:48:26.6633333+00:00
Follow https://techcommunity.microsoft.com/kb/microsoft-365-insider-kb/join-the-microsoft-365-insider-program-on-windows/4401748
If you run into problems, refer to https://learn.microsoft.com/en-us/answers/questions/5312141/can-t-switch-to-beta-channel-excel
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
0 additional answers
