How to validate JWT with only a public key
Neščivera Ján (ERNI) 65 Reputation points
2026-05-12T09:11:55.81+00:00
we have an APIM policy attempting to validate incoming JWT using public key modulus, exponent and id.
This policy however seems to not validate JWT signature for some reason. When I change key modulus, exponent or id, the validation still passes and request is forwarder to backend. If I change audience or issuer in the policy, the validation fails as expected.
What is the proper way to validate incoming JWT when we only have acess to public key of the identity provider?
Azure API Management
An Azure service that provides a hybrid, multi-cloud management platform for APIs.
Siddhesh Desai 8,210 Reputation points Microsoft External Staff Moderator
2026-05-12T11:00:15.41+00:00
Hey @Neščivera Ján (ERNI)
Thank you for reaching out to Microsoft Q&A.
As discussed on teams and with the Product team backend.
The validation is failing as expected now when n/e changes to some wrong value however when key id in policy is changed to some wrong value (aka. value not matching kid claim in JWT), the JWT validation passes which is an expected behavior. The Product team will update the Documentation accordingly.
If the resolution was helpful, kindly take a moment to click on 210246-screenshot-2021-12-10-121802.pngand click on Yes for was this answer helpful. And, if you have any further query do let us know.
1 additional answer
    2026-05-12T09:12:17.8233333+00:00
    Use the validate-jwt policy with an asymmetric issuer signing key configured from the public key. The signature is validated against the public key; if the modulus/exponent are wrong, validation must fail.
    To validate with only a public key, configure one of these options in the validate-jwt policy:
    1. Use an OpenID configuration endpoint (recommended)
    <validate-jwt header-name="Authorization" require-scheme="Bearer">
      <openid-config url="https://login.microsoftonline.com/{tenant}/v2.0/.well-known/openid-configuration" />
      <audiences>
        <audience>api://your-api-app-id</audience>
      </audiences>
      <issuers>
        <issuer>https://login.microsoftonline.com/{tenant}/v2.0</issuer>
      </issuers>
    </validate-jwt>
    openid-config causes API Management to pull the JWKS (public keys) from the identity provider and use them to validate the JWT signature. This is the simplest and most robust way when only the public key is available.
    1. Use modulus and exponent directly
    If the OpenID configuration endpoint cannot be used, specify the RSA public key via issuer-signing-keys with n and e:
      <issuer-signing-keys>
        <key id="your-kid" n="{base64url-modulus}" e="{base64url-exponent}" />
      </issuer-signing-keys>
      <audiences>
      </audiences>
      <issuers>
        <issuer>https://your-issuer</issuer>
      </issuers>
    </validate-jwt>
    Key points to ensure signature is actually validated:
    1. Do not disable signing
    Make sure require-signed-tokens is not set to false:
    <validate-jwt header-name="Authorization" require-scheme="Bearer" require-signed-tokens="true">
    </validate-jwt>
    If require-signed-tokens is false, the token is accepted without signature validation, which matches the behavior described (changing key values has no effect).
    1. Configure issuer-signing-keys correctly
    Within issuer-signing-keys:
    • Use <key id="..." n="..." e="..." /> for an RSA public key.
    • n and e must be Base64url-encoded values of the modulus and exponent.
    • If id is set, it is matched to the token’s kid claim; if no kid matches, API Management will try all keys.
    If the key element is misconfigured but require-signed-tokens is false, the token still passes. With require-signed-tokens="true", a mismatched n/e causes validation to fail.
    1. Ensure other required elements are present
    For full validation, configure:
    <audiences>
      <audience>...</audience>
    </audiences>
    <issuers>
      <issuer>...</issuer>
    </issuers>
    and keep require-expiration-time at its default true unless there is a specific reason to allow tokens without exp.
    1. Alternative: certificate-based public key
    If the public key is available as a certificate uploaded to API Management, use certificate-id instead of n/e:
      <key certificate-id="your-cert-id" />
    This also validates the signature using the public key from the certificate.
    In summary, to ensure the JWT signature is actually validated when only a public key is available, configure validate-jwt with either openid-config or issuer-signing-keys (n/e or certificate-id) and keep require-signed-tokens="true". If changing modulus/exponent has no effect, the policy is likely not using those keys (for example, because require-signed-tokens is disabled or the token is not signed with an asymmetric algorithm supported by the policy).
