A Microsoft Viva module that provides insights and recommendations designed to improve productivity and wellbeing.
The available information describes how Focus plans work and how to change or leave them, but does not document any supported way to extend automatic scheduling beyond the standard behavior or to fix a pattern where focus time stops auto‑scheduling after a week.
From the documented behavior:
- A focus plan “automatically books focus time for you every day based on the preferences you set” and shows focus time “over the upcoming two weeks.”
- After enrollment, the plan keeps booking time and you can monitor it in the Viva Insights app under the Wellbeing tab → Track your progress → Focus plan card.
- If focus time is missing, the supported actions are to adjust the plan settings or leave and re‑enroll:
- In any Viva Insights tab, select the ellipses (…) → Settings.
- Select Protect time.
- Edit scheduled focus hours per day, morning/afternoon preference, and reminder/notification preferences, then save.
- If needed, select Leave plan, complete the short survey, and then select Leave plan again, and then set up the plan again.
If the plan still stops scheduling after a week even after changing settings or leaving and re‑joining, this behavior is not covered by the documented configuration options and would require product support investigation.
As a partial workaround while this is unresolved, single, non‑recurring focus sessions can be booked manually:
- Open Viva Insights in Microsoft Teams.
- Go to the Wellbeing tab → Act with intention → Focus → Book focus time.
- Use the arrows next to the date to navigate the week and select Book for the desired time slots.
These one‑time sessions are added to the calendar but are not part of the recurring focus plan.
