I need some help creating the formula to extract data from a CSV data file
JoePerp 0 Reputation points
2026-05-10T05:00:18.8833333+00:00
The CSV file produces the sample 2 lines of data User's image
I need a formula that will populate the following columns:
Number Temp Number Type
2 R
1 M 1 Veg
Microsoft 365 and Office | Excel | Other | Other
    2026-05-10T05:00:30.1633333+00:00
    Given a text like
    • 2 x Rare Filet with Lobster
    • 1 x Medium Filet with Lobster, 1 x Vegetarian
    in cell A2, the following formulas can be used to populate the columns:
    1. First Number (before the first " x ")
    =VALUE(LEFT(A2,FIND(" x ",A2)-1))
    2. First Temperature letter (R/M/etc.)
    =LEFT(MID(A2,FIND(" ",A2)+1,20),1)
    This takes the first letter of the first word after the initial number (R for Rare, M for Medium).
    3. Second Number (if present, after the comma)
    =IFERROR(
        VALUE(MID(A2,FIND(",",A2)+2,FIND(" x",A2,FIND(",",A2)+1)-FIND(",",A2)-2)),
    If there is no second item, this returns blank.
    4. Second Type (e.g., Veg)
    =IFERROR(
        LEFT(TRIM(MID(A2,FIND(",",A2)+1,50)),3),
    This returns the first three letters of the second item description (Veg from Vegetarian).
    Adjust cell references as needed for the actual data range and copy the formulas down.
