Hi Aaditi,
I understand how inconvenient it can be when the Microsoft Rewards progress does not update even after you have spent time browsing in Microsoft Edge.
In the meantime, please try the steps below and check whether the Rewards progress starts updating:
- Make sure the same account is being used
- Open Microsoft Edge.
- Go to Edge > Settings > Profiles
- Check which Microsoft account is signed in.
- Then open: https://rewards.bing.com
- Make sure the Rewards page is using the same Microsoft account.
- Use a normal Edge window
- Please avoid using InPrivate browsing when completing Microsoft Rewards activities.
- Close any InPrivate windows, open a regular Edge window, sign in again, then try browsing/searching through Bing from Edge.
- Clear cookies and cache for Edge
- Open Edge.
- Go to Edge > Settings > Privacy, search, and services > Clear browsing data
- Select Cookies and other site data and Cached images and files.
- Choose a time range such as All time.
- Click Clear now.
- Restart Edge and sign in again.
- Temporarily disable extensions
- Go to Edge > Settings > Extensions
- Temporarily turn off extensions such as ad blockers, privacy blockers, script blockers, VPN/proxy extensions, or similar tools.
- Restart Edge and test the Rewards activity again.
- Test with a new Edge profile
- Open Edge > Click your profile icon.
- Select Set up new personal profile or Add profile.
- Sign in with the same Microsoft account.
- Visit Bing Rewards and try the activity again.
Please note that this is a user-to-user support forum. Moderators, contributors including external Microsoft employees cannot directly intervene in Microsoft product features or access back-end systems. Our role is limited to providing technical guidance on reported issues, requests, or ideas.
If the issue still persists after trying all the steps above, please contact Microsoft Rewards Support by following the guidance provided in the AI-generated answer, so the Rewards team can review your account/activity status further.
Wishing you a smooth experience while completing your Rewards activities without further interruptions.
