Build 28020.2075 out to Canary/Exp. Channel
CrazyKats 19,595 Reputation points Volunteer Moderator
2026-05-08T19:06:34.16+00:00
    2026-05-08T19:06:57.7233333+00:00
    Build 28020.2075 is not mentioned in the provided release notes. The latest documented Experimental (26H1) / Canary 28000-series build in the context is 28020.1921, which is already live in Windows Update for devices in that channel and is described as including general improvements and fixes.
    For Canary / Experimental (26H1) devices:
    • These builds are unstable, may have limited documentation, and features can change or be removed.
    • Features are rolled out gradually using Controlled Feature Rollout, so availability can vary by device.
    • To be among the first to receive new features, enable the toggle under Settings > Windows Update (for Canary) or use the Feature flags page under Settings > Windows Update > Windows Insider Program (for Experimental (26H1)).
    • To see which build is currently in which channel, use Flight Hub.
    If a newer build such as 28020.2075 is visible on a device’s Windows Update but not yet documented, it follows the same Insider guidance: it may be an incremental update with limited or delayed release notes and is part of the ongoing transition from Canary 28000-series to the Experimental (26H1) channel.
