A family of Microsoft presentation graphics products that offer tools for creating presentations and adding graphic effects like multimedia objects and special effects with text.
The kerning difference between the “electronic distribution and accessibility” PDF and the “print” PDF comes from how the electronic export path processes fonts, especially on macOS, and how specific fonts/versions behave in that pipeline.
The electronic option:
- Uses a Microsoft online service to create a tagged, accessible PDF and to preserve hyperlinks on objects.
- Handles font embedding and layout differently from the local print export, which can expose issues with certain fonts (older formats, multiple versions, or very large font sets) and result in altered kerning or substituted fonts.
To mitigate the problem while keeping an electronic PDF:
- Check and update the fonts
- On macOS, verify the installed font versions. If multiple versions of the same font exist, ensure the newest one is active.
- If the font type shows as “PostScript-Type1”, replace or upgrade it to a modern OpenType version. Older Type 1 fonts and duplicate fonts are known to cause garbled text, substitutions, and other display issues in Office for macOS.
- Test with a different OpenType font in the same slide. If the kerning issue disappears in the electronic PDF, the problem is specific to the original font and the online conversion service.
- Manually tune spacing/kerning in PowerPoint
- Windows:
- Select the affected text.
- Go to Home → Font dialog launcher.
- Open the Character Spacing tab.
- Adjust Spacing (Expanded/Condensed) and, if needed, the Kerning for fonts settings to compensate for the difference seen in the electronic PDF.
- macOS:
- Select the text.
- Choose Format → Font → Character Spacing.
- Set Spacing to Expanded or Condensed and tweak the By value (start with 0.1–0.2 pt) and Kerning for fonts until the exported electronic PDF visually matches the print PDF.
- Windows:
- Choose export path based on priority
- For exact typography (kerning) above all else, use the print‑optimized PDF export, which does not use the online service and therefore avoids this kerning behavior.
- When clickable links on objects are required, PowerPoint for macOS preserves them only with Best for electronic distribution and accessibility (uses Microsoft online service). In that case:
- Prefer modern OpenType fonts that behave correctly with the electronic export, or
- Provide two files: a print PDF for precise layout and an electronic PDF for interactivity.
If, after switching to a modern OpenType font and removing duplicate/Type 1 versions, the issue only affects that specific font in the electronic export, it indicates a font‑specific compatibility problem with the online conversion service. Using a different OpenType font is the recommended workaround.
