Express Circuit Failover
Abrar Adil S 476 Reputation points
2026-05-07T18:05:57.61+00:00
We have the following ExpressRoute setup configured in Azure:
  • 2 ExpressRoute circuits from different providers
  • 2 ExpressRoute connections
  • 1 Virtual Network Gateway connected to both circuits
The design expectation is that if one ExpressRoute circuit goes down, traffic should automatically fail over to the second active circuit without impacting connectivity.
However, when one circuit went down, connectivity was disrupted even though the second circuit and connection remained active. We had to manually remove the circuit which was down to make the another circuit up and running
We would like to understand:
  1. Why traffic did not automatically fail over to the active ExpressRoute connection.
  2. Whether this is an expected ExpressRoute routing behavior or limitation.
  3. What is the recommended Microsoft best practice to achieve proper high availability and site resiliency so that failure of one circuit/site does not impact connectivity through the other active connection.
Azure ExpressRoute
Azure ExpressRoute
An Azure service that provides private connections between Azure datacenters and infrastructure, either on premises or in a colocation environment.
  1. Vallepu Venkateswarlu 10,590 Reputation points Microsoft External Staff Moderator
    2026-05-07T19:22:56.2633333+00:00
    Hi @ Abrar Adil S,
    Welcome to Microsoft Q&A Platform.
    It sounds like you expected seamless failover across two different ExpressRoute circuits but saw a full outage when one circuit went down. Here's what’s likely happening and how to architect for true high availability:
    Why you didn’t see automatic failover
    • By default each ExpressRoute circuit operates in active-active only on its own two redundant connections. Azure treats the two circuits you added as separate resources and will prefer one path based on BGP attributes (weight, local-pref, AS-path prepends or communities). If the “preferred” circuit goes into a failed provisioning state (rather than just BGP session flapping), Azure doesn’t immediately withdraw all routes or shift traffic to the other circuit—you often have to “Refresh” or manually disable that peering to force a switch.
    • If you’ve inadvertently prepended AS paths or set unequal local-preference on the second circuit, Azure will keep advertising and trying to use the primary until you tear down the failed one.
    Is this expected behavior?
    • Yes. ExpressRoute’s cross-circuit failover relies on clean BGP convergence. A circuit in a failed provisioning state doesn’t behave like a simple BGP flap. Azure will hold onto the resource until you disable/refresh that peering. This is a known limitation—you won’t get an instant automatic switch until routes are actually withdrawn.
    Best practices for true HA and resiliency a. Active-Active at every level
    Reference
    https://docs.microsoft.com/azure/expressroute/designing-for-high-availability-with-expressroute#active-active-connections
    https://docs.microsoft.com/azure/expressroute/design-architecture-for-resiliency
    Please210246-screenshot-2021-12-10-121802.pngand “up-vote” wherever the information provided helps you, this can be beneficial to other community members.
