Certificate for completing class 3025
Moseke, Cheryl 0 Reputation points
2026-05-06T23:31:44.9066667+00:00
Could you direct me where to find my certificate of completion for completing class 3025
    2026-05-06T23:31:57.41+00:00
    Certificates and certifications are managed through Microsoft Learn and the credentials area, not directly by class number.
    To locate a certificate of completion:
    1. Sign in to Microsoft Learn with the same account used for class 3025.
    2. Go to the Credentials area where completions and certifications are listed:
      • Use the Certifications tab for earned credentials and to view/print/save them as PDF.
    3. If the certificate does not appear, follow the missing-certifications guidance to verify the account and associations, as described in the credentials documentation.
    4. If it is still not visible, submit a support request to certification/credentials support so the team can check the record and re-associate or restore access to the certificate.
    For older training or if the certificate is not visible under the Certifications tab, open a support request as described in the credentials support guidance so the support team can investigate and help retrieve or reissue access to completion records.
