help me with Skype
A J 0 Reputation points
2026-05-04T05:30:22.6733333+00:00
i need to talk with someone on how to reactivate my skype account
Microsoft Teams | Microsoft Teams Free | Sign up and Sign in | Switch between accounts
    2026-05-04T05:30:39.3033333+00:00
    To reactivate or get help reactivating a Skype account and its services, contact Skype support directly and work with a support agent.
    Use one of these paths from the provided resources:
    1. Start from the Skype help site
      • Go to the Skype help & learning page where Skype support options are listed.
      • Select Contact Skype support.
      • Choose the option that best matches the issue (for example, I need help with my Skype account or I can't access or use paid services).
      • Follow the prompts to reach Skype Customer Support (chat or other available channels) and request account reactivation or investigation.
    2. If Skype services are partially blocked
      • If any message appears such as “Your Skype account has been suspended”, “Some features on your account are blocked”, or “Your account has been restricted from using Skype's paid features”, this indicates restrictions on the account.
      • In this case, contact the Skype Customer Support team using the dedicated support contact link provided in the article about partially blocked services and explain that account reactivation is needed.
    3. If the issue is with Skype for Business
      • If this is a Skype for Business (work) account, help is provided through Microsoft Office Support. Use the Skype for Business help article to navigate to Office Support and then contact support from there.
    If direct phone contact with Microsoft is preferred (for broader Microsoft account or billing issues related to Skype), use the customer service phone numbers page and follow its instructions to reach support, then ask specifically for help reactivating the Skype account.
  2. Ruwim.B 6,900 Reputation points Volunteer Moderator
    2026-05-04T05:51:58.7566667+00:00
    Skype services are no longer available, but you can now transfer all Skype data to Teams using the same credentials as you have used with Skype.
    https://support.microsoft.com/en-us/office/moving-from-skype-to-microsoft-teams-free-3c0caa26-d9db-4179-bcb3-930ae2c87570
    If you have some remaining Skype credit and need to reactivate this credit, then you can do this using this reactivation site:
    https://calling.web.skype.com/account/credit_reactivation
    Just be sure to sign in to this site with exactly the same account as you have used with Skype.
