Microsoft Edge en macOS Tahoe
Eugenio Menendez Florez 0 Reputation points
2026-05-01T18:59:18.5566667+00:00
Descargo Edge de la web de Microsoft, Instalo en Aplicaciones. Lo abro y me pide confirmar si abrir por haber descargado desde Internet. Confirmo OK pero NO SE ABRE. Solo tiembla el pictografía y no hace nada.
Microsoft Edge | Install and update | MacOS
    2026-05-01T19:41:30.3033333+00:00
    Hi there,
    Thank you for posting your question here!
    When the Edge icon bounces and stops it usually means macOS security or a corrupted install is blocking the app from launching. The fastest fix is to fully remove Edge then reinstall clean. Delete Microsoft Edge from Applications then go to Finder Go to Folder and remove any Microsoft Edge folders under Library Application Support and Library Caches. Restart the Mac then download Edge again from Microsoft, drag it to Applications, right click it and choose Open to bypass Gatekeeper.
    Let me know if this resolves the issue. To help the Community and guide others with the same concern please let us know if this reply solved your problem by clicking Yes or No below.
    Best Regards,
    Angelique P.
