Build 28020.1921 out to Canary Channel
CrazyKats 19,595 Reputation points Volunteer Moderator
2026-05-01T17:04:05.38+00:00
    2026-05-01T17:04:25.5366667+00:00
    Build 28020.1921 is a Windows 11 Insider build for devices in the Canary 28000 series channel, which is in the process of transitioning to the new Experimental (26H1) channel naming. These Canary/Experimental builds:
    • Are early, potentially unstable platform builds and can ship with limited documentation.
    • May include features that change, are removed, or never ship beyond Insider channels.
    • Often use Controlled Feature Rollout, so features might appear only for a subset of devices at first.
    • Show a desktop watermark as they are pre-release builds.
    To receive this build, ensure the device is enrolled in the Canary 28000 series channel and check Settings > Windows Update. Turning on the toggle to get the latest updates as they are available will deliver new features sooner as they roll out.
    To leave the Canary channel later, a clean install of a stable Windows 11 build is required.
