SSO differences between Entra ID joined devices and others
passione 120 Reputation points
2026-04-30T14:54:44.15+00:00
Hello everyone,
I want just to ask if there are any difference on how an SSO implementation of Entra ID could work on joined/Hybrid joined/registered devices and unregistered devices.
Thanks.
    2026-04-30T14:55:05.4633333+00:00
    SSO behavior in Microsoft Entra ID differs mainly based on whether the device has a cloud device identity (joined/hybrid joined/registered) and which SSO mechanism is used.
    1. Device types and SSO mechanism
    • Microsoft Entra joined devices
      • Device is joined directly to Microsoft Entra ID (no on-prem AD join).
      • SSO is provided via the Primary Refresh Token (PRT), not Kerberos.
      • Gives SSO to Microsoft Entra–protected apps and, when the device can reach a domain controller, SSO to some on-premises resources as well.
      • SSO works automatically in Microsoft Edge and in Chrome with the browser extension.
      • Authentication uses modern OAuth/OpenID Connect protocols over the internet.
    • Hybrid Microsoft Entra joined devices
      • Device is joined to on-premises AD and registered in Microsoft Entra ID.
      • Also uses PRT-based SSO for Microsoft Entra–protected resources.
      • Can additionally use Kerberos/NTLM for on-premises apps because the device has an on-prem computer account.
      • SSO via PRT is the recommended method on Windows 10/11 and takes precedence over Seamless SSO when both are enabled.
    • Microsoft Entra registered devices (personal/BYOD)
      • Device is not domain-joined; a work/school account is added (“Add work or school account”).
      • Device gets a cloud identity and uses PRT-based SSO to Microsoft Entra–protected apps.
      • Good for BYOD scenarios; still supports Conditional Access and compliance when managed.
    • Unregistered devices
      • No device object in Microsoft Entra ID.
      • No PRT, so no device-based SSO.
      • Users authenticate per app/session (e.g., interactive sign-in, possibly Seamless SSO if the device is domain-joined and on-prem, but not Entra joined/registered).
      • Conditional Access can’t evaluate device state (compliant, hybrid joined, etc.), so device-based controls don’t apply.
    1. Seamless SSO vs PRT-based SSO
    • Seamless SSO
      • Signs users in automatically when on a domain-joined device on the corporate network.
      • Works with Password Hash Sync or Pass-through Authentication.
      • Not used on Windows 10 Microsoft Entra joined, Microsoft Entra hybrid joined, or Microsoft Entra registered devices.
    • SSO via PRT
      • Recommended for Windows 10, Windows Server 2016, and later.
      • Used on Microsoft Entra joined, hybrid joined, and registered devices once they are registered with Microsoft Entra ID.
      • Provides SSO to Microsoft Entra–protected apps and is the primary SSO mechanism for those device states.
    1. Impact on Conditional Access and management
    • Microsoft Entra joined / Hybrid joined
      • Device has a cloud identity, can be managed by Intune, and supports device compliance and Conditional Access policies.
      • Hybrid joined also has an on-prem AD identity and can use GPOs and on-prem auth (Kerberos/NTLM).
      • Device identity exists in Entra ID; can be managed (e.g., via Intune) and participate in Conditional Access based on device compliance.
    • Unregistered
      • No device identity in Entra ID; Conditional Access can only use user and session signals, not device state.
    In summary: joined, hybrid joined, and registered devices all use PRT-based SSO and support richer Conditional Access and management. Unregistered devices lack PRT-based device SSO and device-based Conditional Access.
