An Azure artificial intelligence service and end-to-end platform for applying computer vision to specific domains.
Azure Vision in Foundry Tools provides ready-made computer vision capabilities that can be used directly from applications without building or training custom machine learning models.
- Core features in Azure Vision (Foundry Tools)
Azure Vision includes several major capabilities:
- Image Analysis
- Extracts visual features from images such as:
- Objects
- Faces
- Adult/racy content
- Auto-generated tags
- Auto-generated natural-language descriptions
- The Image Analysis 4.0 API is the latest version and adds:
- Synchronous OCR (Read OCR) for images
- People detection
- Can be accessed via SDKs or the REST Analyze Image API.
- OCR (Optical Character Recognition)
- Extracts printed and handwritten text from images, including:
- Photos of street signs, products, posters, screenshots
- Text-heavy images and multi-page PDFs (via the Document Intelligence Read OCR model for documents)
- Azure Vision OCR in Image Analysis 4.0:
- Fast, synchronous API optimized for non-document, “in-the-wild” images
- Supports printed and handwritten text in many languages using script-based models
- Returns text plus structure via the
readResultsection in the Analyze Image response.
- Face
- Detects, recognizes, and analyzes human faces in images.
- Supports scenarios such as identification, touchless access control, and face blurring.
- Thumbnail generation
- Analyzes an image to find the area of interest and generates a high-quality thumbnail, optionally with a different aspect ratio than the original.
- Integrating Azure Vision without custom ML models
Azure Vision is exposed as managed APIs and SDKs, so integration does not require ML expertise:
- Use client SDKs or REST APIs
- Image Analysis 4.0 can be called via:
- Client library SDKs (for example, .NET, Python, etc.)
- Direct REST calls using the Analyze Image API (
https://aka.ms/vision-4-0-ref).
- For OCR with Image Analysis 4.0:
- Call the Analyze Image API and include
Readin thefeaturesquery parameter. - Parse the
readResultsection of the JSON response for extracted text.
- Use SynapseML / Synapse Analytics (no ML model building)
- In Azure Synapse Analytics with SynapseML, Vision can be used as Spark transformers:
AnalyzeImage– extract tags, objects, faces, adult content, descriptions. -
OCR/RecognizeText– read text from images. -
DescribeImage– generate human-readable descriptions. -
ReadImage– used in the tutorial to run OCR and return results in a Spark DataFrame.
- Example (OCR in SynapseML):
df = spark.createDataFrame([ ("<replace with your file path>/ocr.jpg", ) ], ["url", ]) ri = (ReadImage() .setLinkedService(ai_service_name) .setImageUrlCol("url") .setOutputCol("ocr")) display(ri.transform(df)) - This pattern lets applications use Vision from data pipelines without training or deploying models.
- Typical use cases
- Text extraction (OCR)
- Extract printed and handwritten text from:
- Product labels, street signs, posters, screenshots
- Business documents, invoices, receipts, reports, letters, whiteboards (for text-heavy documents, use Document Intelligence Read OCR model).
- Power scenarios like:
- Knowledge mining and search
- Business process automation (invoice processing, form intake)
- Accessibility (screen-reading of images)
- Image analysis and tagging
- Automatically tag images with objects and concepts.
- Detect faces and adult/racy content.
- Generate natural-language descriptions of images.
- Example from SynapseML tutorial: analyzing a dog image returns tags like
"dog", "outdoor", "fence", "bench".
- Thumbnail generation and content-aware cropping
- Generate thumbnails that focus on the most important region (e.g., a person’s face) while fitting a required aspect ratio.
- Face-based scenarios
- Detect, recognize, and analyze human faces for:
- Identification and verification
- Touchless access control
- Privacy-preserving face blurring.
- Domain-specific content detection
- Detect and identify domain-specific content in images (as demonstrated in the SynapseML tutorial).
Note: Real-time video analysis is not a primary Azure Vision scenario in this context. For advanced video analysis (transcription, translation, summarization), Video Indexer is recommended instead.
- Limitations and prerequisites
From the provided context, the key considerations are:
- Service scope and when not to use Azure Vision
- Use Azure Vision for:
- Extracting printed and handwritten text from images and documents via OCR.
- Analyzing images for objects, faces, and descriptions.
- Detecting and analyzing human faces.
- Do not use Azure Vision for:
- Advanced video analysis (use Video Indexer).
- Content safety moderation (use Content Safety in Foundry Control Plane).
- Tasks already covered by large multimodal foundation models like GPT‑4o.
- API behavior and performance
- Image Analysis 4.0 OCR:
- Synchronous, optimized for non-document images and near real-time experiences.
- Document Intelligence Read OCR:
- Asynchronous, optimized for text-heavy PDFs and scanned documents.
- Requires polling via a “Get Read Results” operation to retrieve results.
- Deprecation notice
- Image Analysis 4.0 in Azure Vision in Foundry Tools is marked as deprecated and will be retired on September 25, 2028. After that date, calls to this service will fail.
- Migration to alternatives outlined in the migration guide is recommended.
- Language support
- OCR supports several languages for printed text.
- Handwritten OCR is currently supported exclusively for English (for the legacy OCR described in the transparency note).
- General prerequisites
- An Azure AI Foundry / Azure Vision resource and keys.
- For SynapseML usage:
- Azure Synapse Analytics workspace.
- SynapseML library configured.
- Linked service to the Azure AI service (
ai_service_namein examples).
File formats, size limits, and region-specific availability are not detailed in the provided context; those details are typically documented per API in the service reference and should be checked there when designing production solutions.
