How to fix there was a problem resetting your PC Automatic Recovery failed
Charles Haynes 0 Reputation points
2026-04-27T21:53:44.18+00:00
During a Windows update on my windows 11 pro operating system the update crashed my hard drive. The update did not restart my system. I manually turn it on and got a message saying there was a problem with my automatic windows repair. The system restarts and the BitLocker page appears asking to Enter the recovery key to get going again keyboard layout US
The page provides me with the links on how to find my key. Following a instructions on the page I enter my Microsoft account at aka.ms/myrecoverykey but no key is displayed. I have attempted for approximately ten hours contacting Microsoft to help me discovery my recovery key only to be shuffled from one support group to another.I am hoping this support ticket will provide me with whom I may contact to help me with this BitLocker recovery key issue. I have an O365 business account for approximately 15 years with multiple windows 11 clients. Please help
Windows for business | Windows Client for IT Pros | User experience | Session connectivity
  1. Domic Vo 33,190 Reputation points Independent Advisor
    2026-04-27T22:50:10.22+00:00
    The message you are seeing is the standard BitLocker recovery screen. When Windows fails to boot after an update and automatic repair cannot complete, BitLocker protection is triggered to ensure the drive remains secure. The system is asking for the recovery key because it cannot continue without it.
    The recovery key is not generated by Microsoft support staff on demand; it is tied to your device and stored in one of several locations depending on how BitLocker was configured. The official lookup site at aka.ms/myrecoverykey only shows keys that were backed up to your Microsoft account. If nothing appears there, it means the key was not saved to that account. In that case, you need to check the other supported storage locations:
    • If the device was joined to Azure AD or Intune, the recovery key is stored in the Azure AD device object. An administrator can retrieve it from the Azure portal under Azure Active Directory > Devices > All devices > [Device] > BitLocker keys.
    • If the device was domain‑joined, the key may be stored in Active Directory. It can be retrieved from the computer object in AD Users and Computers under the BitLocker Recovery tab.
    • If the key was saved locally, it may be printed, written down, or stored as a .txt file on a USB drive. By default, Windows prompts to save the key during BitLocker setup.
    • If the key was stored in a hardware TPM‑bound configuration without backup, there is no way to bypass it. Microsoft does not provide alternative recovery methods if the key is lost.
    Without the recovery key, the drive cannot be unlocked. This is by design to protect data. If you cannot locate the key in any of the above locations, the only option is to reformat the drive and reinstall Windows, which will result in data loss.
    Given your description, the most likely scenario is that the key was never saved to your Microsoft account but may still exist in Azure AD or AD if the device was managed. If this is a personal device not joined to a domain, you will need to check any USB drives, printed documents, or saved files created when BitLocker was first enabled.
    I hope you've found something useful here. If it helps you get more insight into the issue, it's appreciated to accept the answer. Should you have more questions, feel free to leave a message. Have a nice day!
    Domic Vo.
  2. AI answer
    2026-04-27T21:54:11.5533333+00:00
    BitLocker recovery requires the correct 48‑digit recovery key. If the key cannot be found, Windows cannot be unlocked or reset without data loss.
    Follow these steps in order:
    1. Enter the BitLocker recovery key On the BitLocker recovery screen, type the 48‑digit key (hyphens are optional). If the key is correct, Windows will start normally.
    2. Find the BitLocker recovery key If nothing appears at aka.ms/myrecoverykey, check all possible locations listed in the official guidance:
      • Microsoft account (for personal devices) – sign in and check all profiles that might have been used on this device.
      • Work or school account / Intune – if this is an organization‑managed device, the key may be stored in Azure AD/Intune. An IT admin can retrieve it using the Intune “Get recovery key for Windows” process.
      • Printed copy, USB drive, or file – check any printouts, USB sticks, or files where the key might have been saved when BitLocker was first enabled.
      • Organization helpdesk – if the device is managed by a company or school, contact the IT department; they may have escrowed the key.
      Use the guidance in:
    3. If the recovery key cannot be found
      • Without the BitLocker recovery key, the encrypted drive cannot be unlocked. None of the Windows recovery options (Automatic Repair, Reset this PC, Startup Repair, reinstall) can access the data without that key.
      • If the key truly cannot be located in any of the places above, the only remaining option is to wipe/repartition the drive and reinstall Windows. This will permanently erase all data on the encrypted volume.
    4. Reinstall Windows if recovery options fail If Automatic Repair and other recovery options do not work, and the BitLocker key is available or the drive has been wiped:
      1. On another working PC, create Windows 11 installation media (USB/DVD) from Microsoft’s official download page.
      2. Boot the affected PC from that installation media.
      3. If the drive is still BitLocker‑encrypted and you have the key, enter it when prompted so Setup can access the drive. If you do not have the key, delete the encrypted partitions during setup and install Windows to the unallocated space (this erases all data).
      4. Complete Windows setup.
      This aligns with the documented guidance that if the PC will not start and recovery options like Startup Repair or System Restore fail, Windows must be reinstalled using installation media.
    If this is a work or school device, contact the organization’s IT admin and explicitly ask them to retrieve the BitLocker recovery key from their management system (Azure AD/Intune/AD) before attempting any reinstall.
