Need an agent for help with email
JIM ANDERSON 0 Reputation points
2026-04-27T16:44:39.5133333+00:00
Need to speak to a tech support agent regarding adding an alternate recovery email address
    2026-04-27T16:44:50.0666667+00:00
    To speak with a tech support agent about adding an alternate recovery email address for an Outlook.com account, use Microsoft’s official support channels:
    1. Go to Outlook.com and sign in to the account that needs help.
    2. Select Help on the menu bar.
    3. In the Help pane, type a short description such as “add alternate recovery email” or “manage account security”.
    4. Follow the self-help suggestions. If the issue is not resolved, scroll down to the Still need help? section and select Yes to reach support options.
    5. Use the available option (such as chat) to connect with a support agent and explain that assistance is needed adding or updating a recovery email address.
    If sign-in is not possible, use the Outlook.com support entry point for locked-out users:
    • Go to the “If you can't sign in” support page for Outlook.com and follow the prompts to reach support and/or the account recovery form.
    For broader Microsoft account and billing help (including security info and recovery options), support is also available via the Account & Billing Help portal.
