Where can I get certificate for module completion?
Su Yadanar 0 Reputation points
2026-04-27T08:03:11.5933333+00:00
    2026-04-27T08:03:21.4333333+00:00
    Certificates for completed Microsoft Learn modules and learning paths are managed through the Microsoft Learn profile and the Credentials area, not issued individually per module as downloadable certificates.
    To view and use earned certifications:
    1. Go to the Credentials page on Microsoft Learn: https://learn.microsoft.com/users/me/credentials/?tab=credentials-tab
    2. Sign in with the same account used to complete training or pass exams.
    3. Under the Credentials/Certifications area, view the certifications that have been awarded.
    4. Certificates are no longer provided as direct downloads; instead, open the certification, then use the browser’s print function and choose “Save as PDF” to keep a copy, or share/verify using the options described here: https://learn.microsoft.com/credentials/certifications/cred-share-validate.
    If an expected certification or badge is missing after passing an exam or completing required learning, contact Microsoft Credentials Support via https://aka.ms/credentialssupport so the dedicated team can review the account and fix visibility or delivery issues.
