Bug in Azure Flex Consumption Plan
Dimitrios Bardis 5 Reputation points
2026-04-24T10:29:39.3733333+00:00
1. Problem Summary
My Azure Function App (Flex Consumption) is VNet‑integrated and configured to call Azure Document Intelligence through a Private Endpoint. DNS resolution inside the Function App resolves the endpoint to the correct private IP, and a curl test from the Function App container returns HTTP 200. However, the actual outbound call made by the function runtime is sent from a public outbound IP, not from the VNet‑integrated subnet. As a result, Document Intelligence rejects the request with:
Code
403: Traffic is not from an approved private endpoint
This indicates that Flex Consumption is starting function workers that are not VNet‑integrated, even though the Function App is configured for VNet integration. I need confirmation whether this is expected behavior
2. Technical Details
Environment:
Azure Functions Flex Consumption plan
Python Function App
VNet integration enabled
Private Endpoint for Document Intelligence
Private DNS zone linked to the same VNet
Public network access disabled on the Cognitive Service
Terraform‑based deployment
Observed behavior:
DNS resolution inside the Function App container is correct:
The hostname
Code
ragdocintsvc.cognitiveservices.azure.com
resolves to the private endpoint IP:
Code
10.50.0.69
curl test from the Function App container succeeds:
Code
HTTP 200 Service Operational
This confirms:
Private DNS zone is correct
Private Endpoint is correct
VNet integration works on this instance
However, the actual outbound call made by the function runtime uses a public outbound IP:
Code
Outbound IP: 74.241.138.252
This proves that the worker executing the function is not VNet‑integrated, even though the Function App is configured for VNet integration.
Document Intelligence rejects the call:
Code
This is expected when the request reaches the public endpoint instead of the private one.
Conclusion:
Flex Consumption appears to be scaling out to workers that are not attached to the VNet, causing inconsistent outbound routing. This makes Private Endpoint access unreliable on Flex Consumption.
Request:
Please confirm whether Flex Consumption guarantees VNet integration for all scale‑out workers. If not, please link to a documentation where it is stated that it does not guarantee that. Is it so that Flex is used for non-private solutions? If Flex is supposed to be used also for private networking then this is a bug.
Azure Functions
Azure Functions
An Azure service that provides an event-driven serverless compute platform.
    2026-04-24T10:29:58.9233333+00:00
    Flex Consumption plan function apps support outbound virtual network integration and are designed to route outbound traffic through the integrated subnet when configured, including for private endpoint scenarios.
    From the documented behavior:
    • Flex Consumption explicitly supports Virtual network integration (outbound) and Private endpoints (inbound) as part of its networking feature set.
    • For Flex Consumption, outbound traffic is routed through shared gateways dedicated to the subnet used for VNet integration. Up to 27 shared gateways (27 IPs) are used per subnet, regardless of how many apps are integrated.
    • The subnet must be dedicated, delegated to Microsoft.App/environments, and at least /27 in size (with /27 recommended for a single app and /26 for multiple apps). Using a smaller subnet or multiple apps on a /27 reduces available outbound network capacity but does not change the expectation that outbound traffic is routed via the VNet integration.
    There is no statement in the referenced documentation that Flex Consumption workers are allowed to bypass VNet integration and send outbound traffic directly from public IPs when VNet integration is configured. The documented model for Flex Consumption is that outbound traffic from function app instances is routed through the shared gateways in the integrated subnet.
    The behavior described (some executions using a public outbound IP and being rejected by a private‑endpoint‑only Cognitive Service) is therefore not documented as expected behavior and is not described as a limitation of Flex Consumption in the provided material. Flex Consumption is documented as supporting private networking via VNet integration, not as a “non‑private only” plan.
    Given the documentation:
    • Flex Consumption is intended to be usable with private networking (VNet integration and private endpoints).
    • There is no documented requirement to move to Premium solely to “guarantee” that some workers are VNet‑integrated while others are not; instead, Flex Consumption’s outbound model is that traffic is routed via the integrated subnet’s shared gateways.
    If this behavior persists with a correctly configured, dedicated, and properly sized subnet, it aligns with a service issue rather than a documented, by‑design limitation.
    For further troubleshooting and escalation:
    1. Verify the subnet used for VNet integration meets Flex Consumption requirements:
      • Dedicated subnet.
      • Delegation: Microsoft.App/environments.
      • Size: at least /27, /26 recommended for multiple apps.
    2. Use the Network troubleshooter for the Function App (Diagnostic and solve problems → Network troubleshooter) to validate:
      • VNet integration status.
      • Private IP assignment to instances.
      • DNS configuration and connectivity to dependencies.
    3. If configuration is valid and the issue continues, this should be treated as a service‑side bug and escalated via Azure Support.
