not able to login to https://XXXX.secureseXXXX.net/
Sayali Durgude 0 Reputation points
2026-04-24T09:28:47.7233333+00:00
I am not able to login to the https://XXXX.secureseXXXX.net/ URL to get access to my domain. I have purchased the domain through Azure services. I have the customer number, user name and password. I did a password reset and it still says username or password is incorrect.
edited pII
Azure App Service
Azure App Service
Azure App Service is a service used to create and deploy scalable, mission-critical web apps.
    2026-04-24T09:29:20.8466667+00:00
    The sign-in issue is with a third-party sign-in portal, not Azure App Service itself. The available guidance in context focuses on general account/password troubleshooting and recovery.
    Use these steps to troubleshoot:
    1. Verify username and domain
      • Ensure the correct username is being used, including any required domain or UPN format (for example, some services require a UPN like ******@contso.com instead of an email alias like ******@contso.com).
      • Double-check spelling of the username (for example, rachel vs rachael).
    2. Confirm the password reset completed
      • After resetting the password, carefully enter the new password again to avoid typos.
      • If the portal still reports “username or password is incorrect,” repeat the reset process to ensure the new password is applied.
    3. Try account recovery options
      • If the service offers an account recovery or “forgot username/password” flow, use it to confirm the account is recognized and to reset credentials.
      • Follow the steps to receive and enter any verification code, then set a new password.
    4. Clear browser state and retry
      • Use InPrivate/Incognito mode or clear browser cookies and site data, then try signing in again.
      • If possible, try a different browser or network to rule out local issues.
    5. Verify the account is active and working elsewhere
      • If the same credentials are used for another portal (for example, a webmail/OWA portal), test sign-in there. If sign-in fails there as well, the issue is likely with the account itself.
    6. Contact the provider’s support
      • If the portal continues to reject the username/password after a successful reset and recovery attempts, contact the account provider’s support team and report that the username has stopped working. Provide the customer number and any error messages so they can verify and fix the account.
    For Microsoft-based accounts (Azure, Microsoft 365, etc.), if a password reset or self-service reset fails with errors, work with the tenant or Active Directory administrator to update account details (such as phone numbers for verification) or to unlock/reset the account.
