Class Notebook and Page Distribution Issues
Jo Stone 0 Reputation points
2026-04-22T16:27:15.9033333+00:00
I wonder if you could help or if you could put me in touch with someone who can help. We have 15 schools in our Trust who use Class Notebook regularly with their pupils. We have been using Class Notebook in these schools for about four years consistently. This year we have had a lot of issues with the distribution of pages and sections to the pupil notebooks.  The teachers are distributing from the teacher only section in the Class Notebook. They often distribute pages to classes (30 pupils) or year groups (90 pupils).  This year the teachers have been trying to distribute pages to their pupils either from their home location or on the school site but they have received error messages. The error messages explain that they have only been able to distribute to 20 out of 30 pupils or it will tell the teachers that the distribution has been completely unsuccessful. Do you have any solutions to this issue? It is happening in a number of our schools not just one.  It is very frustrating for the teachers. They are trying to find their own fixes but this is not ideal - they should be focussed on teaching and learning. I apologise if this is a technical fix and I am asking the question in the wrong forum. I am happy to be redirected or to schedule a Teams call with someone to resolve this issue.
Microsoft Teams | Microsoft Teams for education | Class Notebook | Other
    2026-04-22T16:27:53.53+00:00
    For large classes and year groups, slow or partial page distribution is usually caused by sync load and large content (especially PDFs) being pushed to many student notebooks at once. The following supported practices help reduce errors like “only distributed to 20 of 30 pupils” and failed distributions:
    1. Use the built‑in Distribute Page tool
    • Always distribute handouts and assignments using Class Notebook’s Distribute Page tool rather than copying pages manually. This is optimized for distributing to individual students or groups and helps streamline syncing.
    • See: Distribute Page.
    1. Time distributions to reduce network load
    • Distribute materials after class ends or before it begins so that students’ devices can sync changes at home or outside peak school‑network usage.
    • Avoid pushing large sets of pages to multiple classes at the same time across schools, as this increases the chance of partial distribution and sync errors.
    1. Minimize heavy content in each distribution
    • Large files like PDFs require more bandwidth and take longer to sync to every student notebook and device.
    • Distribute only the PDFs needed for that day’s lesson from the Content Library so student devices sync more quickly.
    • Where possible, split very large PDFs into smaller parts or use lighter content (text/ink) on the distributed page with the PDF as a separate, on‑demand resource.
    1. Force sync after distributing
    • After distributing new materials, force‑sync the Class Notebook:
      • Right‑click the notebook name and select Sync this Notebook.
    • Ask students to force sync when they:
      • Open OneNote at home
      • Finish homework
      • Are about to start class
    • This helps ensure all student notebooks receive the distributed pages and reduces “partial distribution” scenarios.
    1. Close unused notebooks
    • On teacher and student devices, close any notebooks that are not currently in use:
      • Right‑click the notebook and select Close this notebook.
    • Fewer open notebooks means less sync traffic and more reliable distribution to the active class notebook.
    1. Adjust sync behavior on iPads
    • If teachers or students use iPads, turn off Auto Sync Attachments in OneNote settings (Sync page):
      • Text and ink still sync automatically.
      • Pages with rich content (images, PDFs) wait to sync until the page is visited, then sync automatically.
    • This reduces background load when distributing content with attachments to many pupils.
    1. Ensure OneNote is up to date
    • For environments using OneNote 2016, make sure the most recent updates are installed before troubleshooting distribution issues, as older builds can have sync and Class Notebook issues.
    1. Capture diagnostics and contact Education Support if errors persist If teachers still see errors (for example, repeated failures or consistent “only X of Y students received the page”), collect diagnostics and escalate:
    • OneNote for the web
      1. After an error using Distribute Page, press Ctrl + ~.
      2. Class Notebook generates session information; select Export Logs.
      3. A .csv log file downloads.
      4. Go to https://aka.ms/edusupport, fill in the details (including that it affects multiple schools and classes), attach the .csv, and submit.
    • OneNote for Windows 10
      2. A Session ID is generated.
      3. Go to https://aka.ms/edusupport, include the Session ID, and submit.
      4. If logs are needed, reproduce the error in OneNote for the web and export logs as above.
    The Education Support channel at https://aka.ms/edusupport is the correct route for a Trust‑wide issue affecting multiple schools; include sample Class Notebook names, approximate times of failed distributions, and affected user accounts so they can investigate service‑side causes.
  2. Alexis-NG 18,070 Reputation points Microsoft External Staff Moderator
    2026-04-22T16:58:08.5166667+00:00
    Hi Jo Stone,
    Good day, and thank you for articulating your concern so clearly.
    Issues where page distribution only completes for part of a class (for example, 20 out of 30 students) or fails entirely are most commonly linked to synchronization load and service-side processing limits rather than a specific user or device issue. Since the issue is affecting multiple schools, occurs across different locations (home and school), and appears to be consistent and ongoing this year, this strongly suggests that the root cause may be tenant-level or service-side, rather than something individual teachers can resolve locally.
    Given the nature of the problem and your request fora remote session, the most effective next step is reaching out to Microsoft support team with your admin credentials to submit a support request through the Microsoft 365 Admin Center.
    Microsoft also provides customer service phone numbers based on your region. You can find the appropriate contact number here: Customer service phone numbers - Microsoft Support
    This route ensures that a Microsoft support engineer can initiate a remote session to investigate backend configurations, run advanced diagnostic tools, and, if necessary, escalate the case to specialized teams with access to internal systems and logs. These backend resources are essential for resolving issues that go beyond what’s visible in the user interface.
    As community moderators, we’re here to guide you, but due to privacy and security limitations, we don’t have access to the backend tools required for a full resolution. For this reason, contacting Microsoft Support via the Admin Center is the most secure and efficient way forward.
    I hope this helps you resolve the issue quickly. I’m glad to assist and truly hope the information provided has been useful. Please feel free to reach out anytime if you need further assistance.
    If you find my post helpful, kindly consider marking it as the accepted answer. Doing so can assist others in the community who may have similar questions in finding solutions more quickly.
    Thank you for your kindness and contributions to the forum.
    Note: Please follow the steps in this documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
