Survey Response rates and reports
Sarah Kern 0 Reputation points
2026-04-22T06:42:26.7166667+00:00
how can i change the default settings:
These thresholds can be changed by Viva Glint admins, but the defaults are:
  • 5 responses for scores and response rates
  • 10 responses for comments and comment search
  • 2 for suppression behaviour
Microsoft 365 and Office | Microsoft Viva | Viva Insights
  1. Michelle-N 20,735 Reputation points Microsoft External Staff Moderator
    2026-04-22T09:03:24.0066667+00:00
    Hi @Sarah Kern
    Based on the information you provided, I understand that you are looking to modify the default reporting thresholds in Viva Glint, specifically the minimum requirements for scores (5), comments (10), and suppression behavior (2).
    Here is how you can manage these settings:
    -Use this method if you want all future surveys to follow the same configuration by default.
    Log in to the Viva Glint Admin Dashboard > Navigate to Configuration > Service Configuration > Advanced Configuration > In the Details section, locate and update the following fields:
    • Confidentiality threshold (Minimum Sample Size): This controls the minimum responses needed for scores and response rates (Default: 5).
    • Comments thresholds: This controls the visibility and searchability of comments (Default: 10).
    • Suppression threshold: This controls the data suppression mechanism (Default: 2).
    Then select Save Changes.
    -If you have a specific project that requires higher or lower privacy levels than your global defaults, you can adjust them individually.
    Go to Configuration > Service Configuration > Advanced Configuration > Select Surveys and click on the specific survey you wish to edit > Update the thresholds for scores, response rates, or comments as needed > Select Save Changes.
    Note: Ensure the survey is currently in Draft status.
    There is one critical rule to keep in mind for all survey types: Viva Glint Admins can only adjust reporting thresholds before a survey program launches its first survey. Once the program begins collecting response data, these thresholds become locked and cannot be changed.
    Please refer the following documents:
    Manage Viva Glint confidentiality thresholds
    Manage Viva Glint Advanced Configuration settings and tasks
    I hope this helps!
