How to come with a expediting structure
Joash Becko 20 Reputation points
2026-04-21T22:32:06.4433333+00:00
swim lane for expediting
the chart with diagram
the process
summary
Microsoft 365 and Office | Visio | For business | Other
AI answer
2026-04-21T22:32:22.7133333+00:00
An expediting structure with swimlanes in Visio is best built as a cross-functional flowchart. Swimlanes represent who or what is responsible for each step (for example: Team, Role, or Priority such as “Expedite”), and the process steps are placed inside the appropriate lane.
A simple approach:
  1. Create the base diagram
    • Start Visio.
    • In Categories, select Flowchart.
    • Choose Cross Functional Flowchart, then Create.
    • When prompted, choose Horizontal or Vertical orientation for the swimlanes.
    • The template opens with swimlanes already on the page.
  2. Define swimlanes for expediting
    • Use each swimlane to represent a function or priority, for example:
      • Normal Work
      • Expedite
      • Review/Approval
      • Completed
    • To add more swimlanes (Windows):
      • Right-click an existing swimlane header and choose Insert ‘Swimlane’ Before or Insert ‘Swimlane’ After, or
      • On the Cross-functional Flowchart tab, in the Insert group, select Swimlane, or
      • From the Cross-Functional Flowchart Shapes stencil, drag a Swimlane shape and drop it where it should appear.
    • To add swimlanes on the web, use the same options: right-click header → Insert ‘Swimlane’ Before/After, the Swimlane button on the Cross-functional Flowchart tab, or drag a swimlane from the stencil.
  3. Build the expediting process
    • From the Cross-Functional Flowchart Shapes stencil, drag process step shapes (e.g., Start/End, Process, Decision) into the appropriate swimlane.
    • When a shape is correctly contained in a swimlane, the lane shows a green highlight; contained shapes move automatically with the lane.
    • Use connectors between shapes to show the flow: normal path in the “Normal Work” lane, and the fast-track path in the “Expedite” lane.
    • If needed, use Separator lines (web) from the Cross-Functional Flowchart Shapes stencil to indicate phases such as “Intake,” “Expedite Decision,” “Implementation,” and “Done.”
  4. Label and format for clarity
    • Click or double-click placeholder text in the diagram and swimlane headers to type labels such as “Expedite,” “Triage,” “Approval,” etc.
    • To reposition labels (Windows), use Home → Tools → Text Block, then drag the label.
    • To change label orientation (Windows), use Cross-functional Flowchart → Design → Rotate Lane Label.
    • On the web, adjust text alignment via Home → Align Text.
  5. Adjust structure as the process evolves
    • Resize lanes by dragging separator lines or end lines to fit more or fewer steps.
    • Reorder lanes by dragging a lane (after clicking its label bar so the lane is highlighted) to a new position.
    • Deleting a swimlane removes all shapes it contains, so only delete lanes when sure the contained steps are no longer needed.
Summary of the expediting structure:
  • Use a Cross Functional Flowchart template.
  • Create swimlanes for normal vs. expedite paths (and any key roles or phases).
  • Place each process step in the lane that owns or executes it.
  • Use connectors and separators to show the expedited path clearly from intake to completion.
0 additional answers
