A family of Microsoft products that enable users to capture, organize, and reuse notes electronically.
Follow these steps on the Samsung Tab 10 FE+ to troubleshoot OneNote not loading and sync issues:
- Make sure the tablet is online and syncing is allowed
- Confirm the device has a stable internet connection (Wi‑Fi or mobile data).
- Because OneNote is reporting that it “needs more time syncing,” leave the device powered on and OneNote in the foreground for an extended period, especially if the notebook is large or syncing for the first time.
- Reset OneNote account credentials in the Android app If OneNote opens at least to the Notebooks list or settings, reset the account credentials:
- Open OneNote.
- At the bottom left, tap Notebooks.
- Tap the three‑dots menu in the upper‑right corner and choose Settings.
- Tap Account.
- Tap Sign Out, then OK.
- Use the recent‑apps button, find OneNote, and swipe it away to fully close it.
- Start OneNote again and sign back in with the same account used on the laptop.
- Force a manual sync of the notebook Once OneNote loads and the account is signed in:
- In OneNote, locate the notebook that was not showing notes.
- Tap the three‑dots menu in the upper‑right corner.
- Choose Sync (account name) notebook.
- To sync all notebooks, go to the notebooks list, tap the three‑dots menu, then Sync all.
- Leave the device on and OneNote in the foreground until syncing completes. For large notebooks, this can take a long time.
- Check for app updates on Android If OneNote still will not load properly or continues to show sync errors, update it to the latest version:
- Open the Play Store app.
- Tap the menu icon, then My apps & games.
- If OneNote shows an Update button, tap Update (or Update All).
- After updating, try opening OneNote again and repeat the sign‑in and sync steps above.
- Verify notes on another device or in the browser Since the notes sync correctly to the laptop, confirm that the notebook itself is healthy by opening it there and checking sync status. If the notebook is stored on OneDrive or SharePoint, it can also be opened in a browser via https://www.onenote.com to confirm the latest content is present.
If OneNote continues to fail only on the tablet after these steps (while working on phone and laptop), the issue is likely specific to the Android installation or device environment. In that case, keep OneNote updated from the Play Store and use the web version or another device while waiting for app fixes in future releases.
