How to fix problem with #value
Jan Kronus 0 Reputation points
2026-04-20T12:34:00.4266667+00:00
I have a problem with the value that is displayed in some cells.
Some are correct, and they are set the same.
It is not possible that something is set incorrectly in the formulas settings in Excel
    2026-04-20T12:34:21.7533333+00:00
    The #VALUE! error means Excel cannot calculate the formula because at least one referenced cell has text, spaces, or special characters instead of a clean numeric or date value, even if it “looks” the same as other cells.
    To fix it in this kind of table:
    1. Check for hidden text/special characters in the source columns (for example the date or total columns feeding the “Criação”, “Criação MTH”, “Criação YR” fields):
      • In an empty helper column, use =ISTEXT(<cell>) on the cells that feed the formulas (for example =ISTEXT(H2)), then fill down.
      • Any row that returns TRUE has text or a special character and can cause #VALUE!.
    2. Clean or re‑enter the problematic values:
      • For cells that should be numbers/dates but are detected as text, delete the contents and retype the value manually.
      • Or use CLEAN/REPLACE in a helper column to remove special characters, then copy → Home > Paste > Paste Special > Values back over the originals.
    3. Remove stray spaces in ranges used by the formulas:
      • Select the column with suspect values.
      • Press Ctrl+H (Replace), set Find what to a single space, Replace with empty, then choose Replace All if all spaces are unwanted.
      • If the error persists, turn on a filter (Home > Sort & Filter > Filter), filter for Blanks, then select any “blank” cells that appear and press Delete to clear hidden characters.
    4. Use functions that ignore text where appropriate:
      • If formulas currently use operators like + or * across mixed data (numbers plus text), replace them with functions that ignore text, for example:
        • Replace =A2+B2+C2 with =SUM(A2:C2).
        • Replace =A2*B2 with =PRODUCT(A2,B2).
    5. Evaluate one of the failing formulas step by step:
      • Select a cell showing #VALUE!.
      • Go to Formulas > Evaluate Formula > Evaluate repeatedly.
      • Excel will show exactly which part of the formula becomes " " (space) or text, indicating which input cell must be cleaned.
    After cleaning or retyping the non‑numeric/non‑date cells that the “Criação” columns depend on, the #VALUE! errors will be replaced by the correct calculated results.
