how to fix Store incomplete
Ismael Gomes 20 Reputation points
2026-04-20T08:43:23.6633333+00:00
Dear all;
I just want to know how cause my store is stop running for the windows 8
Pease give me a solution
Windows for home | Previous Windows versions | Microsoft Store
AI answer
2026-04-20T08:43:42.3866667+00:00
For Windows 8 / 8.1 where Store stops working or seems incomplete, use these steps depending on the symptom.
  1. If Store is stuck loading or crashes after upgrade to Windows 8.1
  • This is a known issue after an unexpected shutdown.
  • The fix is an update that is automatically installed when upgrading from Windows 8 to Windows 8.1, as long as there is an Internet connection during the upgrade.
  • Ensure the PC is fully updated via Windows Update so that this Store fix is applied.
  1. If Store or Store apps cannot be opened in Windows 8.1 / Server 2012 R2
  • There is a specific update that fixes issues where Windows Store applications cannot be opened after certain updates.
  • Install all Recommended updates from Windows Update, including the update described for “Can’t open Windows Store applications in Windows 8.1 or Windows Server 2012 R2.”
  • If language packs are needed, install language packs first, then re‑install this update as required.
  1. If Store exits immediately when offline with Arabic (Saudi Arabia) display language
  • On Windows 8.1 / Server 2012 R2 with display language set to Arabic (Saudi Arabia), Store may close immediately when there is no Internet connection.
  • Install the November 2014 update rollup for Windows 8.1 / Windows Server 2012 R2 to correct this behavior.
  1. If Store apps tiles are missing on first logon (Windows 8 / RT)
  • On some OEM Windows 8 / RT devices, only a few tiles (Desktop, File Explorer, Internet Explorer, Store) appear and other Store app tiles never show.
  • Install the Windows 8 and Windows Server 2012 update rollup 2836988 to fix the provisioning/installation timing issue for in‑box AppX packages.
  1. General Store repair step (Windows 8.1 and later)
  • Reset the Store cache:
    1. Press Windows key + R.
    2. Type wsreset.exe and select OK.
    3. A blank command prompt opens, then closes; Microsoft Store reopens automatically.
After applying the relevant updates and running wsreset.exe, restart the PC and try opening Store again.
1 additional answer
  1. Bulldog 4,625 Reputation points
    2026-04-20T14:33:50.8+00:00
    The Microsoft Store for original Windows 8 (RTM) was officially shut down in July 2019, preventing new app downloads or updates. For the updated Windows 8.1, the store stopped accepting new purchases on January 10, 2023, and completely ceased distributing app updates on June 30, 2023.
