How to solve the problem that the hardware driver certification submission window cannot be found in Microsoft Partner Center
Maxeye 0 Reputation points
2026-04-20T07:44:37.89+00:00
  1. Log in to Microsoft Partner Center
  2. Unable to find the Hardware Center window to submit the HLK certification test report and obtain the certificate
Microsoft Partner Center API
    2026-04-20T07:44:55.9+00:00
    In Partner Center, HLK (hardware driver) certification submissions are done through the Hardware dashboard under Drivers. If the “Hardware Center” or submission entry point is not visible, verify these points:
    1. Confirm registration for the Windows Hardware Developer Program
      • The account must be registered for the Hardware Developer Program before any hardware/driver submission options appear.
      • Follow the steps in “Register for the Microsoft Windows Hardware Developer Program”.
    2. Open the Hardware dashboard (not the general Partner Center areas)
      • Go to the Partner Center hardware dashboard home page.
      • In the left navigation, select HardwareDrivers.
      • On the Drivers page, the button Submit new hardware is the entry point for HLK/WHCP submissions.
    3. Submit the HLK package from the Drivers page
      • Select Submit new hardware.
      • In Packages and signing properties, provide a product name.
      • Upload the .hlkx/.hckx package created from HLK (or a WLK .cab package if using WLK).
      • Complete any questionnaires and select the required OS signatures.
    4. If the submission entry is still missing
      • If the account is correctly registered and the DriversSubmit new hardware option still does not appear, use official dashboard support:
        • Go to Windows developer support → Non-Technical Support – DashboardAsk Copilot and, if needed, open a support ticket for Partner Center dashboard access issues.
    These steps correspond to the current hardware submission flow; there is no separate “Hardware Center window” beyond the Hardware → Drivers → Submit new hardware path.
