Repeated Event 41 Kernel-Power Critical Errors causing Windows 11 Laptop to Restart
Alex Wood 25 Reputation points
2026-04-17T01:16:13.51+00:00
I've had this problem for a quite a while now and it causes my laptop to restart about two or three times a day. I'll be in the middle of watching a video or it'll just be sat idle and suddenly the screen goes black and it starts back up again. It happens infrequently enough to still be usable in most situations but it's still incredibly irritating.
I checked the Event Viewer and every time it does this there is an Event 41 Kernel-Power error. I've tried everything I can find on the internet to fix this. I've altered the power settings, disabled fast startup, updated BIOS to the latest version, disabled hardware-accelerated GPU scheduling, updated every driver I have, run the memory diagnostic tool (no errors found), ran memtest86 just to be sure (still no errors found), performed DISM and SFC scans with command prompt (neither have ever found anything wrong), checked the temperature to ensure it's not overheating, cleaned the fans anyway just in case, never used overclocking in the first place. I've taken it in to "professionals" to fix and they charged me £75 and took 2 weeks just to do a full system reboot which clearly fixed nothing because literally five minutes after turning it on it experienced another crash. I've also tried to repair it with the Windows 11 Disk Image ISO files multiple times.
It's very frustrating to have everything under the sun tell you that there is no problem when clearly something isn't working properly. I don't consider myself the most tech-savvy person but my efforts to save this thing have certainly taken me on a journey. Still it seems whatever is causing the issue is still beyond my grasp.
System Info:
Lenovo Legion 5 17ARH05H
AMD Ryzen 7 4800H with Radeon Graphics (2.90 GHz)
NVIDIA GeForce GTX 1660 Ti
16 GB installed RAM (15.4 GB usable)
Windows 11 Home 25H2
Most recent Minidump Files: https://drive.google.com/file/d/1gBIByiVrWU7bkLZIHCGD_Ekeq0InEiZk/view?usp=drive_link
Lester Bernard Reyes 84,725 Reputation points Independent Advisor
2026-04-18T01:12:37.1033333+00:00
Hi, upon checking and analyzing the event logs you have, there is a significant error with Kernel-Power, which means there is an error with the hardware itself. This might happen when the processor is overheating, getting low power from the motherboard, or in the power supply. In this case, I recommend updating your BIOS, and if the issue persists, I suggest contacting a local technician to physically check the device for any hardware-related issues.
5 additional answers
  1. Luis Armando Irua Alpala 0 Reputation points
    2026-08-23T17:30:59.9566667+00:00
    Ami me pasa igual estoy intentando de todo 206631
