Frequent Allocation Failures in Node Pool (OverconstrainedAllocationRequestError)
Ramesh Kumar Pepakayala (TECH MAHINDRA LTD.) 0 Reputation points Microsoft External Staff
2026-04-11T07:33:40.1366667+00:00
We are encountering frequent allocation failures in our node pool Standard-Basic-NPI Pool for South Central US location.
Azure Batch
Azure Batch
An Azure service that provides cloud-scale job scheduling and compute management.
  1. Nikhil Duserla 9,945 Reputation points Microsoft External Staff Moderator
    2026-04-14T09:30:17.1533333+00:00
    Hello @Ramesh Kumar ,
    This is a known and expected behavior in Azure.
    It indicates that the required physical hardware for your selected VM size is temporarily unavailable in west US. Azure VM capacity depends on the availability of physical hardware within each region and availability zone. When a specific zone runs out of capacity for a particular VM SKU, new deployments or allocations for that size cannot be completed.
    Not to impacting your business operations since the VM is required for critical workloads. To avoid encountering the same issue in the future, it is recommended to select multiple availability zones during deployment, which helps improve resiliency and increases the likelihood of capacity availability.
    Please note that this is a temporary capacity constraint and is not caused by any misconfiguration in your environment. Sometimes redeploy can resolve the allocation issues.
