How do I activate edge browsing streak on rewards?
Aarav K 45 Reputation points
2026-04-10T11:02:38.8266667+00:00
I am facing an issue with activating the Edge Browsing Streak (30 minutes daily usage).
When I click on “Get started” or “Activate streak”, it redirects me to Bing or an information page and nothing gets activated. There is no confirmation or progress shown.
I am a Microsoft Rewards Gold member, and this feature is already working on one of my other accounts under similar conditions. However, on this account it does not activate even though I appear to be eligible and in a supported region.
Things I have already tried:
  1. Using Microsoft Edge while signed into my account
Opening the Rewards dashboard directly
Clicking the activation option multiple times
  1. Keeping a consistent region setup
The issue still continues.
I would like to know:
Is this feature enabled account-wise or region-wise?
Does Gold membership affect eligibility?
Is this a known issue with the activation process?
Any help would be appreciated.
Thank you.
Bing | Microsoft Rewards
nobuko c 125.1K Reputation points Independent Advisor
2026-04-10T12:11:40.2833333+00:00
According to the support information, the description is as follows:
https://www.microsoft.com/en-us/rewards/edge-browsing-streak?
“The Edge Browsing Streak offer is available to select Microsoft Rewards members
in the United States, Canada, the United Kingdom, Germany, France, Australia,
and Japan.”
Since it is available only to select Microsoft Rewards members, it appears that there are certain eligibility conditions, and the offer is not always available to all users at all times.
2 additional answers
    2026-04-10T11:02:50.7366667+00:00
    The available context only documents how Microsoft Rewards streaks and streak protection work in general; it does not describe an “Edge Browsing Streak” feature, its activation flow, or any known issues specific to it. It also does not state whether such a feature is controlled per account, per region, or by membership level (e.g., Gold), so those questions cannot be answered from the provided information.
    The only supported guidance in the context for Microsoft Rewards issues that do not behave as expected is to contact Microsoft Rewards Support so the account can be checked directly. Use the Rewards Support form at the Microsoft Rewards site to have the Rewards team review eligibility and configuration for that specific account.
  2. Christyan Campos 10 Reputation points
    2026-06-17T11:18:18.2333333+00:00
    You gotta login on Edge to be able to earn these points.
    I could only activate it after i logged in into Microsoft Edge with synchronizing on...
