How to fix Database Engine Tuning Advisor not working with SQL Server 2022 Express Edition
Mohamed Mahmoud Agwa 20 Reputation points
2026-04-09T22:33:27.78+00:00
I am using Microsoft SQL Server 2022 Express Edition on Windows 10 Pro.
When I try to open or connect using the Database Engine Tuning Advisor (DTA) through SQL Server Management Studio, I receive the following error:
"Database Engine Tuning Advisor does not support SQL Express."
My SQL Server version is: Microsoft SQL Server 2022 (RTM-GDR) - Express Edition (64-bit)
I want to confirm:
  • Is Database Engine Tuning Advisor completely unsupported in SQL Server Express Edition?
  • Or is there any configuration or workaround to enable it?
If it is not supported:
  • What are the recommended alternatives for query performance tuning in SQL Server Express?
SQL Server Analysis Services
A Microsoft online analytical data engine used in decision support and business analytics, providing the analytical data for business reports and client applications such as Power BI, Excel, Reporting Services reports, and other data visualization tools.
AI answer
2026-04-09T22:33:42.8266667+00:00
Database Engine Tuning Advisor (DTA) is not supported for SQL Server Express Edition, including SQL Server 2022 Express. The error message is expected behavior and there is no configuration change or workaround to enable DTA against an Express instance.
For query performance tuning with SQL Server Express, use alternative approaches and tools that are supported with Express:
  1. Use SQL Server Management Studio (SSMS) query tools
  2. Use dynamic management views (DMVs)
    • Query DMVs such as sys.dm_exec_query_stats, sys.dm_exec_sql_text, and sys.dm_db_index_usage_stats to identify high-cost queries and missing or unused indexes.
  3. Use query and index design best practices
    • Review query patterns, ensure appropriate indexing on predicates and joins, and avoid unnecessary scans.
  4. Use workload-based analysis without DTA
    • Capture a representative workload using Extended Events or Query Store (if available in the specific Express build) and manually analyze execution plans and resource usage.
DTA itself cannot be enabled or used directly with SQL Server Express; tuning must be done using the above manual and SSMS-based methods instead.
0 additional answers
