CFA Audit mode
Nayak, Jitendra 0 Reputation points
2026-04-06T18:18:53.6866667+00:00
Controlled Folder Access has been deployed via SCCM in Audit mode, reflected internally as value **4
Could you please confirm what should be the value for audit?**
Microsoft Security | Intune | Configuration Manager | Other
  1. Prathista Ilango 1,080 Reputation points Microsoft Employee
    2026-04-08T13:32:09.14+00:00
    Hello Nayak, Jitendra,
    4 is Audit disk modification only.
    Refer to: https://learn.microsoft.com/en-us/windows/client-management/mdm/policy-csp-defender#enablecontrolledfolderaccess
    The equivalent SCCM policy setting would be - Audit disk sectors only. Refer to: https://learn.microsoft.com/en-us/intune/configmgr/protect/deploy-use/create-deploy-exploit-guard-policy#bkmk_CFA
    Hope this helps!
    If you found the information above helpful, please Click Yes. This will assist others in the community who encounter a similar issue, enabling them to quickly find the solution and benefit from the guidance provided.
  2. AI answer
    2026-04-06T18:19:03.57+00:00
    For Controlled Folder Access, the numeric values for the EnableControlledFolderAccess rule state are:
    • 0 = Disabled (Off)
    • 1 = Enabled (Block mode)
    • 2 = Audit mode
    So the correct value for Audit mode is 2.
    Note: In some management tools (such as Configuration Manager/Intune), additional internal or UI-specific values can appear, but per the documented CFA rule states, Audit mode corresponds to value 2.
