WHY DO I CONSTANT HAVE A PROBLEM TO SIGN-IN???
Josh Rush 0 Reputation points
2026-04-05T17:33:01.2333333+00:00
WHY am I constantly asked to sign-in at msn when I wish to comment and when I try to sign-in it continuously tells me there is a problem???????
Microsoft Edge | Profile, sync, and sign in | Windows 11
    2026-04-05T17:33:17.5033333+00:00
    The repeated sign-in prompts and “there is a problem” message when trying to comment on MSN are typically caused by either:
    1. A Microsoft account sign-in problem
    2. A browser sign-in/cookie issue
    3. An MSN-side restriction on commenting
    Use these steps in order:
    1. Confirm Microsoft account can sign in
    2. Fix sign-in loops related to support.microsoft.com-style authentication If the page appears to redirect and then reloads the same sign-in page (a loop):
      • In Internet Explorer or Microsoft Edge, make sure these sites are not in the Trusted sites list, or if policy requires one of them to be trusted, add all of them so cookies can be shared correctly:
        1. microsoft.com
        2. support.microsoft.com and any subdomains
        3. login.live.com
        4. login.microsoftonline.com
      • After adjusting the security zone settings, close the browser, reopen it, sign in at https://login.live.com, then go back to MSN and try commenting again.
    3. Ensure MSN is using the signed-in Microsoft account
      • On the MSN home page, sign in from the top of the page using the Microsoft account that successfully signed in at account.microsoft.com.
      • MSN uses that Microsoft account to sync personalization and to enable services like comments.
    4. If comments are restricted or blocked on MSN
      • Long-term inability to comment (even when signed in) can be due to MSN’s own moderation or account restrictions.
      • Use the Feedback option at the bottom right of an MSN page where comments appear. Describe that the MSN account has been restricted or that sign-in is repeatedly requested and fails when trying to comment. The MSN team uses this channel to investigate comment-related issues.
    5. If still unable to access Outlook.com/Hotmail/MSN mail
      • For email sign-in issues that might be related (same account), use the Outlook.com sign-in page and, if needed, the account troubleshooter linked from the Outlook.com sign-in help article.
    If the problem persists after confirming the Microsoft account works, fixing browser security zones, and submitting MSN feedback, the issue is likely on MSN’s side (comment system or moderation), which must be handled by the MSN team via the feedback mechanism.
