The behavior is typically caused by policy or management restrictions, not by the Acer hardware.
In Windows 11, the Send optional diagnostic data toggle is controlled under:
- Start → Settings → Privacy & security → Diagnostics & feedback.
If the switch immediately turns itself off or is greyed out, it usually means:
- The device is managed by an organization (work/school account, MDM, or Group Policy). In that case, the page shows a message like “Some settings are hidden or managed by your organization”, and the diagnostic level is enforced so optional data cannot be enabled.
- A policy or configuration has been applied that forces only Required diagnostic data. Optional diagnostic data cannot be turned on manually when such a policy is in effect.
To participate in the Windows Insider Program, optional diagnostic data must be allowed. If the setting keeps reverting:
- Check the top of Settings → Privacy & security → Diagnostics & feedback for the “managed by your organization” message.
- If present, contact the administrator or remove any work/school management that is enforcing the policy, then try again.
- On a personally owned device not joined to any organization, ensure no management or security software is applying Windows policies that restrict diagnostic data.
Once the restriction is removed, the Send optional diagnostic data toggle should stay on, and Insider enrollment can proceed.
