A Microsoft file hosting and synchronization service.
On Android, OneDrive can have only one personal account but multiple work or school accounts. To separate work and personal and stop the wrong account syncing, adjust the accounts in the OneDrive app and on the device.
Follow these steps on the Android phone:
- Check which accounts are signed in to OneDrive
- Open the OneDrive app.
- Tap the profile picture or icon in the top corner.
- In the list of accounts, note which are:
- Personal OneDrive (only one is allowed), and
- Work or school accounts (can be multiple, but not multiple from the same organization).
- Remove the unwanted account from OneDrive
- To stop the phone syncing to the work drive:
- In the OneDrive app, tap the profile picture or icon.
- Tap Sign out on the work or school account that should not sync from the phone.
- If the new personal OneDrive account is not wanted on the phone:
- Tap the profile picture or icon.
- Tap Sign out on that personal account.
- After signing out, only add back the account that should sync from the phone (work or personal) using Add account.
- Re‑add only the correct account(s)
- Open OneDrive.
- Tap Add account.
- Sign in with the account that should be used on the phone:
- If the phone is for personal use, add only the personal OneDrive.
- If work files are needed, add the work or school account as an additional account.
- Control which account uses camera backup
- Only one account can use camera backup.
- In the OneDrive app, ensure camera backup is enabled only on the account that should receive photos (personal or work) and disabled on the other.
- Secure folder and PC link considerations
- If a secure folder or other apps are saving into the wrong OneDrive, change their save location to local storage or to the correct OneDrive account.
- On Windows PCs, OneDrive can also have multiple accounts but only one personal account. Use OneDrive settings on each PC to ensure the correct work and personal accounts are configured and that backup/sync is enabled only where desired.
If sign‑in problems occur or the wrong account keeps appearing, use the “If you can’t sign in to your account” and “If you have two accounts with the same email address” guidance in the references below to clean up overlapping personal vs work identities.
