How to delete messages in phone link
b h 40 Reputation points
2026-03-30T21:16:43.3166667+00:00
For some reason even though I delete the messages on my phone they remain on my PC. I was told to click the X by the side of them but there is no X. I have reset my PC and tried to repair or rest link to windows but it says it cant do this
Windows for home | Windows 11 | Connect Phone and PC
AI answer
2026-03-30T21:16:56.4433333+00:00
Messages shown in Phone Link cannot be deleted from the PC side.
Phone Link only mirrors recent messages from the phone and provides no option to manage or delete them on the PC. Deleting a message on the phone does not remove it from the Phone Link view; the app explicitly does not support message deletion from the PC interface.
Key points:
  • Messages visible in Phone Link are read-only on the PC.
  • There is no X or other control to delete conversations or messages in Phone Link.
  • The app shows only a limited history (for example, recent messages or those from the last 30 days, depending on device/connection), and older ones disappear automatically over time or when Bluetooth connection is ended (for iPhone scenarios).
  • Resetting or repairing the app will not add a delete feature; it only helps with connectivity issues.
To remove messages completely, they must be deleted on the phone itself; Phone Link does not provide a way to delete or manage them from Windows.
5 additional answers
  1. Richard McWolff 5 Reputation points
    2026-07-28T14:13:07.6933333+00:00
    Yes, going into the Settings>Trash and emptying the 🗑️ Trash 🗑️ does delete the unwanted messages on the Windows side of Phone Link but why would you expect us to use the "long way round" to get rid of trashed messages?
    The fix, in my opinion, is once a message is trashed on the phone app side it should automatically be trashed on the Windows side of Phone Link. It's nice to have an option that does work but it's a "long way around" sort of fix that should be more simplified. Thanks
