how do i set up automatic translation for microsoft 365 including documents and emails
Marcie Goodale 0 Reputation points
2026-03-30T14:25:40.2166667+00:00
all documents, files, folder names, emails are in portuguese. i need to have these auto translated to English
Microsoft 365 and Office | Translator | For business
    2026-03-30T14:26:06.34+00:00
    Automatic, tenant-wide translation of all Microsoft 365 content (all documents, file/folder names, and all emails) into another language is not supported as a single global setting. However, several built-in translation features can be enabled or configured to cover key scenarios: emails, Office documents, and SharePoint/OneDrive documents.
    Below are the supported options and how to set them up for English.
    1. Automatic translation of emails in Outlook
    Outlook can automatically translate incoming messages written in other languages into the default language.
    New Outlook for Windows (and Outlook on the web / Microsoft365.com):
    1. When an email in Portuguese arrives, Outlook can show a prompt at the top of the message asking to translate it.
    2. Choose Translate message to replace the message text with English.
    3. To control automatic behavior and language:
      1. Go to the View tab.
      2. Select View settings.
      3. Select MailMessage handling.
      4. Under Translation, choose the preferred options (for example, always translate messages to English).
    If the translate options are missing, Connected experiences may need to be enabled as noted in the Outlook Translator article.
    Classic Outlook for Windows:
    1. On the Home tab, select TranslateTranslate Message to translate the current email.
    2. To change translation preferences and set English as the preferred language:
      1. Go to HomeTranslateTranslation Preferences.
      2. Set English as the preferred language and configure automatic translation behavior.
    These features translate message content, not folder names or message list columns.
    1. Translation in Word, Excel, and PowerPoint
    Office desktop apps can translate selected text or entire documents into English, but this is per-document, not automatic for all files.
    To translate text in Word, Excel, or PowerPoint:
    1. Highlight the text or cell(s) to translate.
    2. Select ReviewTranslate.
    3. Choose English as the target language to see the translation.
    4. Select Insert to replace the original text with the translated text (in Word and PowerPoint). In Excel, copy/paste from the translation pane.
    Requirements:
    • Available to Microsoft 365 subscribers and Office 2021/2019 (with specific minimum versions) and requires an internet connection and Office connected experiences enabled.
    This does not rename files or folders; it only translates content inside documents.
    1. Automatic document translation in SharePoint and OneDrive (Syntex)
    For documents stored in SharePoint and OneDrive, Microsoft Syntex document translation can automatically create translated copies of files, including into English.
    Prerequisites:
    1. Link a Microsoft 365 tenant to an Azure subscription using pay-as-you-go billing for Syntex document processing.
    2. Be a SharePoint Administrator or have admin credentials to the Microsoft 365 admin center.
    Once the Azure subscription is linked to pay-as-you-go billing, document translation is automatically enabled for all SharePoint and OneDrive sites.
    Managing OneDrive document translation:
    • By default, OneDrive document translation is enabled. It can be turned off in the Microsoft 365 admin center under SetupFiles and contentAutomate content processes with SyntexGo to Syntex settingsDocument translationOneDrive.
    Automatic translation rules:
    • Rules can be created to automatically translate documents:
      • When a new file is added to a library.
      • When data in a column changes.
    • These rules create translated versions of documents (for example, from Portuguese to English) and allow monitoring of processing status via the Translation activity panel.
    This feature translates document content, not file or folder names.
    1. Limitations relative to the requirement
    Based on the available features:
    • Emails: Can be automatically translated into English in Outlook, per user, for message content.
    • Documents (Word/Excel/PowerPoint): Can be translated on demand in the apps; not globally auto-translated for all existing files.
    • SharePoint/OneDrive documents: Can be auto-translated using Syntex rules once configured, but this creates translated copies and does not rename files or folders.
    • File and folder names: There is no supported automatic translation of file or folder names across Microsoft 365.
    To approximate the requested behavior:
    • Enable and configure Outlook translation to always translate Portuguese emails into English.
    • Use Word/Excel/PowerPoint Review → Translate for ad-hoc document translation where needed.
    • If SharePoint/OneDrive is used, configure Syntex document translation with rules to automatically create English versions of newly added or updated documents.
  2. Kai-L 19,145 Reputation points Microsoft External Staff Moderator
    2026-03-30T15:39:31.39+00:00
    Dear @Marcie Goodale,
    Good day, and thank you for providing a clear description of your requirements. I understand that you’re looking for a way to automatically translate Microsoft 365 content, including documents and emails from Portuguese to English.
    From my research, there isn’t a single, end‑to‑end setting that automatically translates all existing documents, file names, folders, and emails at once. Translation is handled per application or service, so the experience differs depending on whether you’re working with emails, Word documents, or other content.
    Please review the answer provided by Q&A Assist above, as it outlines the supported options in more detail. As an additional note, if you don’t see the Translate Document option in Word, be sure to check the Language section under the Review tab.
    For reference: Translate text into a different language - Microsoft Support
    I hope this helps clarify the situation and provides you with workable options. If you have any further questions or need additional assistance, please don’t hesitate to reach out. I’m always happy to help. Have a wonderful day.
