AADDS109 alert persists despite healthy environment (Japan East / Entra Domain Services)
フォルシア株式会社 0 Reputation points
2026-03-30T09:23:49.8+00:00
Issue Summary
We are experiencing a persistent alert in Microsoft Entra Domain Services and would like to request guidance.
  • Service: Microsoft Entra Domain Services
  • Alert ID: AADDS109
  • Alert Name: Resources for your managed domain cannot be found
  • Severity: Critical
  • First detected: 2026-03-22 17:31:05 UTC
  • Last detected: 2026-03-30 0:18:03 UTC
  • Region: Japan East
  • Replica Set: Japan East / aadds-vnet / aadds-subnet
The alert persists and the "Last detected time" continues to update, although the service appears to be functioning normally.
Alert Details
A resource that is used for your managed domain has been deleted. This resource is needed for Azure AD Domain Services to function properly.
Actions Performed
1. Network diagnostics
  • Executed "Diagnose and solve problems" → Network diagnostics
  • Results:
    • VNet: OK
      • Subnet: OK
        • DNS: OK
2. Resource verification
Confirmed that all required AADDS resources exist:
  • Network Interfaces
  • Load Balancer
  • Public IP Address
  • Network Security Group
  • Virtual Network
  • Managed Domain resource
Additional Checks
1. Activity Log
  • Checked for "Delete" operations in the resource group
  • No relevant deletion events found (e.g., Microsoft.Network / Microsoft.Compute)
2. Authentication
  • LDAPS authentication are functioning normally
3. Sign-in logs
  • No abnormal failures or anomalies detected
Current Situation
  • The managed domain is fully operational
  • No impact has been observed in actual usage
  • However, the AADDS109 alert persists and detection time keeps updating
Important Context
  • This issue occurs in a production environment, although no impact has been observed so far.
  • This inquiry is related to a subscription with an active Azure Developer Support Plan
  • Subscription ID can be provided if required
Question
  • Could this alert be caused by internal platform operations (e.g., backend maintenance or resource re-provisioning)?
  • Or does this indicate a hidden inconsistency that requires action from our side?
Any insights or guidance would be greatly appreciated.
Thank you.
Microsoft Security | Microsoft Entra | Other
    2026-03-30T09:24:10.1133333+00:00
    AADDS109 is not documented in the provided material, but similar critical alerts for Microsoft Entra Domain Services (such as AADDS100, AADDS103, AADDS110, AADDS112, AADDS116, and AADDS600) follow a consistent pattern:
    • A critical health alert means the platform believes it cannot fully monitor, manage, patch, or synchronize the managed domain.
    • Some alerts are explicitly marked as unrecoverable and require deletion and recreation of the managed domain (for example, AADDS100 and AADDS110).
    • Other alerts are caused by configuration or policy issues on dependent resources (for example, AADDS116) and must be fixed by adjusting those resources.
    • If critical alerts remain unresolved, AADDS600 indicates that the managed domain can eventually be suspended and even deleted if the condition persists.
    Given that:
    • The alert is critical and the “Last detected time” keeps updating, and
    • All visible resources and basic functionality appear healthy,
    this situation matches the general pattern where the platform’s internal checks detect a problem that is not obvious from basic connectivity or resource existence alone. It can be due to:
    • A platform-side inconsistency in the internal resources or metadata used to manage the domain, or
    • A policy or configuration on one of the AADDS-related resources that blocks required platform operations, even if normal traffic and authentication still work.
    Because AADDS109 is not listed in the public “Troubleshooting alerts” set and the environment is production-like with an active support plan, the recommended path is:
    1. Use Domain Services health to confirm all visible alerts
      • In the Microsoft Entra admin center, open the managed domain and review all health alerts as described in the health article. Ensure there are no additional alerts (for example, policy-related like AADDS116) that might explain the behavior.
    2. Check for restrictive policies on AADDS resources
      • For the managed domain’s network components (virtual network, subnet, NICs, load balancer, public IP, NSG), review operation logs and any applied policies.
      • If any policy is blocking platform operations, relax or adjust it as described for AADDS116 (edit the policy so it is less restrictive on AADDS components).
    3. Engage Azure Support for backend investigation
      • Since the alert is critical, persists, and is not covered by the documented alert list, and the subscription has an Azure Developer Support Plan, open an Azure support request specifically for this AADDS109 alert.
      • Provide the alert ID, region, replica set, and the fact that all visible resources and diagnostics are healthy.
      • Support can check internal platform state and confirm whether this is:
        • A transient or platform-side issue (for example, internal resource or metadata inconsistency), or
        • A hidden configuration/policy problem that requires a specific corrective action.
    4. Monitor for AADDS600
      • Until the root cause is clarified, monitor for AADDS600 (“Unresolved health alerts for 30 days”). If it appears, it indicates that unresolved alerts are blocking critical security updates and may lead to suspension, so the support case becomes urgent.
    In summary, a persistent, updating critical alert like AADDS109, with no obvious resource deletion and normal day-to-day operation, strongly suggests either an internal platform inconsistency or a subtle configuration/policy issue rather than a simple, user-visible deletion. Given the lack of public documentation for AADDS109 and the production-like nature of the environment, resolving this requires an Azure support case so the platform team can inspect and correct the underlying state.
