How to fix hard brick surface duo.
Samsutheen S 0 Reputation points
2026-03-29T20:44:07.7633333+00:00
Microsoft Surface Duo (Partitions Wiped).
​I am writing to request technical repair service for my Microsoft Surface Duo. Due to an accidental error while executing ADB/Fastboot commands, the device's partition table (GPT) and all core OS partitions have been completely wiped.
​Currently, the device only turns on to the Bootloader page. However, since the fundamental partition structure is missing, I am unable to flash the official stock recovery or OS images through standard fastboot methods. The device essentially requires official Microsoft internal service tools (like authorized EDL flashing) to rebuild the partitions and restore the operating system.
​Thank you for your time and support.
Surface | Surface Duo | Operating system
  1. S.Sengupta 32,351 Reputation points MVP Volunteer Moderator
    2026-03-30T02:13:48.3766667+00:00
    The Surface Duo uses a Qualcomm Snapdragon 855, which means it has EDL Mode — Qualcomm's low-level flashing interface that operates below the bootloader. Since your GPT is gone, standard fast boot can't work because there's no partition table for it to reference. EDL bypasses all of that and writes directly to the eMMC/UFS storage.
    Visit:
    https://support.microsoft.com/devices
    Choose:
    Surface → Repair → Out of warranty
    You need the device-specific Qualcomm Firehose programmer (.elf file) for the SM8150
    Microsoft has not publicly released this
    Some community members on XDA Developers (Surface Duo forums) have had partial success — this is worth checking before spending money on repair.
