product key
Albert S Westbrook Jr 0 Reputation points
2026-03-29T02:14:23.6966667+00:00
I'm still running windows 7 ultimate and my product key got knocked out when I changed my computer battery and now when I try to re-activate my windows product key it's getting blocked
Windows for home | Previous Windows versions | Licensing and activation
    2026-03-29T02:14:36.44+00:00
    For Windows 7 Ultimate, a blocked or invalid product key after hardware changes (such as replacing components or on some systems even after certain BIOS/firmware or hardware-related events) usually means Windows can no longer validate the existing license.
    For Windows 7/Vista, error 0xC004F050 (“The Software Licensing Service reported that the product key is invalid”) can appear when trying to reactivate. This typically happens if the license validity interval has expired or the license is not signed correctly.
    Try the following steps on Windows 7 Ultimate:
    1. Re‑enter the product key using the Change product key tool:
      1. Select Start → Computer.
      2. On the toolbar, select System properties.
      3. In the Windows activation section, select Change product key.
      4. If prompted for administrator permission, provide it.
      5. Enter the 25‑character Windows 7 Ultimate product key exactly as printed on the COA sticker or in the original packaging, then select Next.
      6. Follow the Windows Activation Wizard steps to complete activation.
    2. If re‑entering the key still fails or shows it as blocked:
      • Confirm that the key matches the installed edition (Windows 7 Ultimate key only works with Windows 7 Ultimate).
      • If this is a pre‑owned PC or a reused key, the key may already have been used on more PCs than allowed by the Microsoft Software License Terms. In that case, a new product key or another copy of Windows is required.
    3. If the original product key cannot be found:
      • For Windows 7 that came in a box, the key should be on a label or card inside the box.
      • For Windows 7 preinstalled on a PC, the key should be on a sticker on the device. If it is missing or unreadable, contact the PC manufacturer.
    If none of these steps allow activation, the key is likely blocked or invalid and a new license is required.
