Try these steps in order:
- Confirm the code type and where to redeem it
- For an Xbox Game Pass or Xbox gift card code, go to the official redeem page: Redeem Code, sign in with the correct Microsoft account, and enter the 25-character code exactly as shown.
- Make sure the code is for Xbox/Microsoft (not a non-Microsoft retailer card that must be redeemed on another site).
- Check for common redemption issues
- Ensure the code has not already been redeemed on any account (once redeemed, it cannot be used again).
- Double-check that the account used to redeem is the one that should receive Game Pass.
- If the code is a Microsoft 365/Office or Windows product key by mistake, it must be redeemed in the correct place:
- Microsoft 365/Office: sign in to https://setup.office.com/ and enter the 25-character code.
- Windows activation code: on Windows 11 go to Settings → Activation → Change product key.
- If the code shows as invalid or not redeemable
- If the code came from Microsoft Rewards, verify it in Rewards order history and ensure the code is copied correctly. If it still fails, follow the “cannot redeem a code” path or contact Microsoft Rewards support as indicated in the Rewards help.
- If the code was purchased from a retailer and appears to be the wrong or invalid code, contact the retailer as advised in the gift card/code redemption guidance.
- If nothing works
- Use the official Xbox/Microsoft support channel for code redemption issues so an agent can check the code status and region on the back end. The Q&A context recommends contacting Xbox support directly for Game Pass redemption problems.
