Elevate Educator Explorer application not accepting completed learning paths
RAJNEESH MITTAL 5 Reputation points
2026-03-27T16:40:18.4433333+00:00
I have completed both required learning paths for the Microsoft Elevate Educator – Explorer program: 1. Elevate Educator – Explorer (General) 2. Elevate Educator – Explorer (AI) All modules and units are marked completed on my Microsoft Learn profile. However, my Explorer application still shows the learning paths as missing / not accepted. Microsoft Learn ID: RAJNEESHMITTAL-8060 .This issue has persisted for more than 48 hours. Kindly request backend verification and manual sync of my learning record.
#Microsoft Learn
#Microsoft Learn for Educators
#Microsoft Elevate
    2026-03-27T16:40:35.2+00:00
    The Elevate Educator – Explorer application and backend verification cannot be accessed or adjusted. Direct support must handle profile-to-program sync issues.
    For issues where completed learning paths or credentials are not being recognized by a program or portal, the supported actions in the provided material are:
    1. Confirm the correct Learn profile is being used
      • Ensure sign-in to the same Microsoft Learn profile where the modules and units are marked complete. If there are multiple accounts (personal MSA vs. work/school), verify that the Explorer application is using the same login as the completed learning paths.
      • Guidance for managing and confirming the correct Learn profile is described under managing the Microsoft Learn profile.
    2. Use the program’s official support channel
      • For Microsoft Learn for Educators–related portals and benefits, the documented path is to open a support ticket from within the relevant portal when access or recognition of benefits/content does not work as expected.
      • The FAQ for Microsoft Learn for Educators specifies using the Help link in the portal to open a support ticket when benefits or access do not appear after the normal processing window.
    3. Contact Microsoft Credentials Support if the issue is with missing credentials
      • If any certification or exam completion is also not appearing correctly on the Learn profile (which could affect downstream program checks), use Microsoft Credentials Support as documented for missing credentials.
    Given that the learning paths are already marked complete and the issue has persisted beyond the usual propagation window, the next step is to:
    • Verify that the Explorer application is using the same Learn profile as the one showing completion.
    • Then open a support ticket through the appropriate program or portal Help/Support entry so the backend team can manually review and sync the learning record.
