ProcDump - Configurable hang timeout for -h
Martin Setnička 0 Reputation points
2026-03-25T14:01:40.9733333+00:00
Currently ProcDump uses a fixed 5-second timeout for detecting hung windows (-h). This causes false positives in large WinForms / WPF applications.
Request: Allow configurable timeout, e.g.: -h 30 or --hang-timeout 30
Sysinternals
Sysinternals
Advanced system utilities to manage, troubleshoot, and diagnose Windows and Linux systems and applications.
    2026-03-25T14:01:57.1133333+00:00
    ProcDump’s hung window trigger -h uses the same definition of a window hang as Windows and Task Manager: a window that does not respond to window messages for at least 5 seconds. In the current documented version of ProcDump, this 5‑second threshold is fixed and there is no command-line option to configure or override the hang timeout.
    The available -h usage is:
    procdump -h <process>
    which:
    "Write a Mini dump for a process named 'hang.exe' when one of its windows is unresponsive for more than 5 seconds:"
    There is no documented -h <seconds> or --hang-timeout parameter, nor any other option that changes the 5‑second hang detection interval. To avoid false positives in large WinForms/WPF applications, alternative triggers (for example, CPU or memory thresholds with -c, -m, or performance counters with -p) must be used instead of -h.
    Feature requests such as making the hang timeout configurable are not currently exposed as ProcDump options in the provided documentation.
