Azure Foundry Workflow issue
Vinayak Indulkar 0 Reputation points
2026-03-25T07:24:27.24+00:00
I have build a workflow using blank page, and i have flow where user will ask query it will go first to the orchestrator, orchestrator will decide based on the query which agent to call.
Below Orchestrator i have 4 agents. i.e. Policy, Compliance, VDI, and User Management.
Problem statement:
when i asked any question, it goes to the orchestrator and it will decide which agent to call but it does not to that agent and there error start coming and after this error continues to come on every question asked after this. So i need to refresh the page and ask the same question again and that time it will work, So this is the issue.
And i also have integrated this orchestrator workflow with Microsoft teams over there if i ask the question and if it happens the same so after that any question i ask i get the handler issue.
i have added all the if condition below every agent if there is a error or any empty message coming from the agent it should say "Can you please ask the question again?" so this way I'm just completing the loop so that handler issue will be not there but for the orchestrator do we have any safer or robust way to tackle this handler issue on Microsoft teams
so is there any fix to this problem in the workflow
Microsoft Copilot | Microsoft 365 Copilot | Development
    2026-03-25T07:24:52.99+00:00
    The described behavior matches a workflow/handler stability issue rather than a configuration feature that can be fully fixed from the workflow designer alone. The available guidance focuses on making the workflow more robust and easier to troubleshoot, not on a specific “handler issue” fix in Teams.
    Within the workflow itself, the following hardening steps are supported:
    1. Use explicit branching and guards around the orchestrator
      • Model the orchestrator and its downstream agents as a deterministic workflow with clear preconditions and post-conditions for each step.
      • Use if/else branches to handle error or empty responses from the orchestrator, similar to what is already done for the child agents. In the Condition box of an if/else node, use Power Fx with System. and Local. variables to check for:
        • Empty or null output
        • Unexpected types (for example, text where JSON is expected)
      • For example, build conditions with System. variables and route failures to a “fallback” branch that returns a safe message like “Can you please ask the question again?” instead of letting the handler fail.
    2. Validate agent assignments and outputs
      • Ensure every agent node under the orchestrator has an agent assigned; missing agents can cause unexpected workflow output.
      • If the orchestrator or agents return structured data, configure them to output JSON Schema and save that output into variables. Then validate:
        • The JSON schema is valid.
        • The variable types match what downstream steps expect. If Power Fx reports type mismatches, use conversion functions like Text() or Value().
    3. Use Power Fx error troubleshooting patterns
      • If Power Fx formulas in conditions reference variables incorrectly, errors such as “Name isn’t valid” or “Type mismatch” can break the run and lead to repeated failures until the session is reset.
      • Ensure:
        • System variables use the System. prefix.
        • Local variables use the Local. prefix.
        • Types are converted explicitly where needed.
    4. Break complex orchestrations into smaller workflows
      • If the orchestrator coordinates multiple agents with complex logic, timeouts or long-running calls can cause workflow failures that then surface as handler issues in Teams.
      • Recommended mitigation:
        • Break the overall process into smaller workflows.
        • Keep each workflow’s sequence and branching simpler and more deterministic.
    5. General workflow health checks
      • When reproducing the issue in Foundry (before Teams):
        • Verify each node completes in the visualizer.
        • Confirm the chat window shows the expected response or the fallback message instead of an unhandled error.
        • Inspect saved variables (especially JSON outputs) to ensure they contain the expected values.
      • If a run times out or produces unexpected output, adjust the workflow as above before re-testing in Teams.
    For Teams integration specifically, there is no separate configuration in the provided guidance that eliminates handler errors. The recommended approach is to:
    • Make the orchestrator workflow deterministic and guarded (if/else, validation, and fallback branches) so that every path returns a valid response.
    • Ensure agents and tools used by the orchestrator are resilient and idempotent, with clear error handling, so that repeated calls from Teams do not leave the workflow in a bad state.
    If, after applying these patterns (guards, correct variable usage, JSON validation, and breaking down complexity), handler errors still persist in Teams, the next step is to capture a failing run in the Foundry visualizer and escalate through support, as the remaining issue is likely platform-side rather than something that can be fixed purely in the workflow definition.
