Problem with Microsoft for Startups
MrVraya 25 Reputation points
2026-03-24T02:34:00.34+00:00
I am a Microsoft for Startups member and I am unable to access
the Founders Hub dashboard.
Every time I try to access foundershub.startups.microsoft.com
or portal.startups.microsoft.com, I get redirected to the
signup/registration page instead of my account dashboard.
I have already activated my Azure subscription successfully
($1,000 credits are active and visible in the Azure portal),
so my account exists and was approved. However, I cannot access
the Founders Hub benefits section (GitHub Enterprise, LinkedIn,
Visual Studio, etc.) because the portal keeps sending me back
to the signup page.
Things I have already tried:
  • Logging in with my Microsoft account
  • Logging in with LinkedIn
  • Clearing cache and cookies
  • Using incognito mode
  • Different browsers
Could someone from the Microsoft for Startups team please
reset my account state so I can access the dashboard and
benefits?
Thank you.
Moved from: Microsoft 365 and Office | Subscription, account, billing | For business | Other
Azure | Azure Startups
Startups: Companies that are in their initial stages of business and typically developing a business model and seeking financing.
    2026-03-24T02:34:15.37+00:00
    The issue is related to Microsoft for Startups/Founders Hub account state and must be fixed by the Microsoft for Startups support team.
    To get the account reset and regain access to the Founders Hub dashboard and benefits, use the official Microsoft for Startups support channels:
    1. Sign in to the Microsoft for Startups Portal: https://portal.startups.microsoft.com/login
    2. Select the “?” icon in the top-right corner.
    3. Choose “Submit a Support Ticket”.
    4. Clearly describe that:
      • Azure sponsorship credits are already active and visible in the Azure portal.
      • Access to foundershub.startups.microsoft.com and portal.startups.microsoft.com always redirects to the signup/registration page instead of the dashboard.
      • Cache, cookies, incognito, different browsers, and different sign-in methods have already been tried.
    5. Attach screenshots of:
      • The Azure portal showing the active $1,000 sponsorship subscription.
      • The redirect behavior from Founders Hub/Startups portal.
    If sign-in or eligibility cannot be verified through the portal, submit a Microsoft for Startups support request directly using the dedicated support form referenced in the Azure signup troubleshooting guidance.
    For technical/break-fix issues with Azure services themselves (not portal access), use the Basic or Developer support plan that comes with the startup credits by opening a support request from the Azure portal.
