Casting display disconnects without prompting
Heidi Weege 0 Reputation points
2026-03-23T16:46:17.92+00:00
I would like to cast my display to a projector. To do so I've been typing windows K, my projector is found, I connect and then within less than a minute, it disconnects. What do I need to do to make my display cast without disconnecting?
Windows for home | Windows 10 | PC projection
    2026-03-23T16:46:35.86+00:00
    Follow these steps to improve stability when casting from a Windows 10 PC so the connection does not drop:
    1. Confirm Miracast support and Wi‑Fi
      1. Select Start > type Connect > open the Connect app. The text will indicate whether the Windows 10 device supports Miracast.
      2. Select the Network icon on the taskbar and make sure Wi‑Fi is turned on.
    2. Verify the projector and adapter
      1. Make sure the projector supports Miracast and that its wireless display feature is turned on.
      2. If the projector does not support Miracast natively, use a Miracast adapter (dongle) plugged into its HDMI port and ensure it is powered and on the correct input.
    3. Install and configure Wireless Display (if projecting to a PC) If projecting to another Windows PC instead of a projector:
      1. On the target PC, go to Start > Settings > System > Projecting to this PC.
      2. Under Add the “Wireless Display” optional feature to project to this PC, select Optional features.
      3. Select Add a feature, search for wireless display, check Wireless Display, then select Install.
      4. After installation, return to Projecting to this PC and configure discovery and security options.
    4. Update drivers and firmware
      1. Update display, Wi‑Fi, and graphics drivers from the PC or device manufacturer.
      2. Check the projector or Miracast adapter manufacturer’s site or app (if available in Microsoft Store) for firmware updates.
    5. Reconnect the wireless display
      1. Press Windows logo key + K.
      2. Select the projector from the list to connect.
      3. If disconnects continue, remove and re-add the device:
        • Open Settings > Bluetooth & devices > Devices.
        • Under Wireless displays & docks, select the projector or adapter and choose Remove device.
        • Then reconnect again using Windows logo key + K.
    6. Reduce interference and distance
      1. Move the PC closer to the projector or adapter (ideally within about 7 m / 23 ft).
      2. Keep the adapter and projector away from sources of radio interference such as microwave ovens and some cordless phones.
    7. Restart devices
      1. Restart the PC.
      2. Power‑cycle the projector and any Miracast adapter.
    If the connection still drops after these steps, test with another Miracast display or adapter to determine whether the issue is with the PC or the projector/adapter.
  2. IGYQ 22,055 Reputation points Independent Advisor
    2026-03-23T17:29:29.2333333+00:00
    Hi!
    Welcome to Microsoft Q&A forum.
    Can I confirm if you have have used the projector before without issues and how far away is the projector to your PC?
    The fastest way to test it if there are interference over wireless connectivity is by using a cable to connect you computer to the projector via HDMI/USB-C. (connection is correct since it can cast few seconds/minutes, it just loses the connection)
