How to fix media player issue
James Henderson 5 Reputation points
2026-03-23T02:57:41.1733333+00:00
Whenever I click on a video or a music file it gives me an error saying, "We couln't open_____ mp3, Wait a bit and try again. 0X800704D".
Windows for home | Other | Music, photos, and video
    2026-03-23T02:57:50.5866667+00:00
    Follow these steps to troubleshoot the Windows Media Player error when opening MP3 or video files:
    1. Check file compatibility
      • Confirm the files are in a format supported by Windows Media Player (for example: MP3, WAV, WMA, AVI, WMV).
      • If the file type is different, convert it to a supported format and try again.
    2. Check codecs
      • The error can occur if the required audio/video codec is missing or corrupted.
      • Install or update the necessary codec packs as described in the Windows Media Player troubleshooting guidance (see reference article for “Install and Update codecs”).
    3. Update Windows
      • Make sure Windows is fully updated, which also updates Windows Media Player components.
      • Go to Start > Settings > Update & Security > Windows Update > Check for updates and install all available updates.
    4. Reset Windows Media Player library
      • Open Windows Media Player.
      • Press Ctrl + M to show the menu bar.
      • Select Tools > Advanced > Restore Media Library.
      • Confirm and let it rebuild the library, then test opening the MP3/video again.
    5. Clear Windows Media Player cache and database
      • Clear cache/history:
        1. Open Windows Media Player and press Ctrl + M.
        2. Select Tools > Options > Privacy.
        3. Under History, select Clear History, then OK.
      • Clear database (if issues persist):
        1. Close Windows Media Player.
        2. Press Windows + R, type %LOCALAPPDATA%\Microsoft\Media Player\ and press Enter.
        3. Delete all files in this folder (do not delete the folder itself).
        4. Restart Windows Media Player and test again.
    6. Update audio and graphics drivers
      • Outdated or faulty drivers can cause playback errors.
      • Update audio drivers (and graphics drivers for video playback) from Device Manager or the PC/sound-card/graphics-card manufacturer’s site.
    7. Check for system or software conflicts
      • Run a full malware scan using installed antivirus software.
      • Temporarily disable or uninstall third-party media-related apps that might conflict with Windows Media Player and test again.
    8. Run the Windows Media Player troubleshooter
      • Use the built-in troubleshooter to automatically detect and fix common issues.
      • On Windows 11: go to Settings > System > Troubleshoot > Other troubleshooters, then select Run next to Windows Media Player.
      • Or use the provided troubleshooter link: Run the Windows Media Player troubleshooter.
    If the error persists after these steps, repeat testing with a known-good MP3 or video file stored locally (not from a network or external drive) to rule out file corruption.
  2. Quinn.HP 9,740 Reputation points Independent Advisor
    2026-03-23T03:43:05.31+00:00
    Hello, I'm Quinn and here to help!
    The previous answer is already helpful. Just to add, I’d recommend running a System File Checker scan. Here's how:
    1. Press Win + S, search and open Command Prompt, Run as administrator.
    2. Type and hit Enter: sfc /scannow
    3. Type and hit Enter: DISM /Online /Cleanup-Image /RestoreHealth
    4. Restart your PC after.
    May I also ask if this issue is happening with a specific file, or if it affects all media files on your system?
  3. Lucus-V 13,115 Reputation points Microsoft External Staff Moderator
    2026-03-31T22:26:16.9133333+00:00
    Hi James Henderson,
    The error code 0X800704D indicates that you have problem with I/O, this could be the audio file is corrupted, or your hard disk is at bad condition.
    Does the problem occur with all media files, or with some specific files only?
    Please download CrystalDiskInfo to check for your hard disk status.
    Disclaimer: Microsoft provides no assurances and/or warranties, implied or otherwise, and is not responsible for the information you receive from the third-party linked sites or any support related to technology.
    If you have any updates, please feel free to let me know.
  4. Mike ONeill 0 Reputation points
    2026-07-02T09:55:00.0133333+00:00
    Please Ignor
