pch VIP ELITE awards and sweepstakes sites not openeing
Clinton Counts 0 Reputation points
2026-03-22T16:50:32.1366667+00:00
pch site not opening? VIP ELITE DAIL awards and sweepstakes sites not opening : https://www.pch.com/pchvip
Microsoft Edge | Website issues | Windows 11
    2026-03-22T16:50:47.07+00:00
    For Microsoft Edge on Windows 11, try these steps to troubleshoot a specific site that will not open:
    1. Clear site data and sign out
      • In Edge, go to Settings → Privacy, search, and services → Clear browsing data.
      • Clear Cookies and other site data and Cached images and files.
      • Close Edge, reopen it, and try the PCH page again.
    2. Turn off experimental TLS flag (if enabled)
      • In the Edge address bar, type edge:flags and press Enter.
      • Search for TLS.
      • Find “1.3 Post-Quantum Key Agreement” and set it to Disabled.
      • Restart Edge and test the site again.
    3. Check tracking prevention and security features
      • In Edge Settings → Privacy, search, and services, temporarily set Tracking prevention to Basic.
      • If any security/AV extensions are installed, temporarily disable them and retry the site.
    4. Try in a different Edge profile or InPrivate
      • Open an InPrivate window (Ctrl+Shift+N) and try the site.
      • Or create a new profile in Edge and test from there. If it works, the issue is likely profile-specific cookies or settings.
    5. If blocked only in the web-wrapper (like Teams Website tab)
      • Some sites block being embedded. If opening inside another app (for example, a Website tab in Teams), open the site directly in Edge instead of inside the app.
    If none of these steps help and other sites work normally, the issue may be on the PCH side rather than with Edge.
