local storage problem
Greey 0 Reputation points
2026-03-22T09:50:51.05+00:00
ssd drive into local image drive installation? Here’s the clear answer: Yes—you can install Windows onto an SSD using a local image (ISO) without needing a USB stick. This is often called a local-drive installation or internal ISO boot, and it works by creating a temporary boot entry that launches Windows Setup directly from your existing drive.
Below is a clean, step‑by‑step guide based on the most reliable method.
🚀 Install Windows on an SSD Using a Local Image (No USB Required) This method is ideal when:
You already have Windows running on your PC
You have a new SSD installed (internal or via USB adapter)
You want to install Windows directly from an ISO stored on your current drive
🧰 What You Need New SSD (connected internally or via USB/SATA adapter)
Windows 10/11 ISO (download from Microsoft)
EasyBCD (free for non‑commercial use)
Existing Windows installation to launch the installer from
🛠️ Step 1 — Prepare the SSD Open Disk Management
Find the new SSD → Initialize as GPT
Create a New Simple Volume
Format as NTFS
Assign a drive letter (e.g., E:)
If you want to keep the installer separate:
Shrink the volume by ~10GB
Create a second partition named Windows Installer
📦 Step 2 — Mount the ISO & Copy Setup Files Right‑click the Windows ISO → Mount
Copy all files from the mounted ISO to the Windows Installer partition
🧩 Step 3 — Add a Boot Menu Entry (EasyBCD) Install & open EasyBCD
Go to Add New Entry → WinPE
Browse to:
Code [Installer Partition]\sources\boot.wim Name it: Windows Installer
Click Add Entry → Save Settings
This creates a boot option that launches Windows Setup directly from your disk.
🔁 Step 4 — Reboot Into the Installer Restart your PC
Choose Windows Installer from the boot menu
When Windows Setup loads:
Select your language
Choose Custom Install
Select the SSD partition you created earlier
Windows will now install directly onto the SSD.
🧹 Step 5 — Clean Up (Optional) After installation:
Boot into the new SSD
Delete the Windows Installer partition
Extend your main SSD partition to reclaim space
📝 Notes & Tips This method is faster than USB installation
Works for Windows 10 and 11
Requires an existing Windows environment
If installing externally for another PC, driver mismatches can cause issues (as noted in Microsoft Q&A)
If you want, I can also walk you through:
Cloning your old drive to the SSD
Doing a clean install vs. migration
BIOS boot‑order setup
NVMe vs SATA installation differences
Just tell me your setup (desktop/laptop, SSD type, and whether you want a clean install or clone).
    2026-03-22T09:51:11.1866667+00:00
    Windows can be installed to an SSD using local media, but the supported and documented methods use bootable external media (USB/DVD), a mounted ISO, or network-based deployment rather than third‑party boot managers.
    From the available documentation, the supported approaches are:
    1. Use a bootable USB or DVD created from an ISO
      • Create Windows installation media from the ISO or via the Media Creation Tool.
      • Boot the PC from the USB/DVD and run Windows Setup.
      • During setup, choose Custom and select the SSD as the target drive.
        This is the standard method described in the Windows Setup technical references and “Install Windows from a Flash Drive.”
    2. Boot from USB and prepare/convert the SSD, then install
      If the SSD is new or needs repartitioning (for example, converting MBR → GPT):
      • Boot from Windows installation USB/DVD in UEFI mode.
      • In Windows Setup, press Shift+F10 to open Command Prompt and use diskpart:
             diskpart
             list disk
             select disk <disk number of SSD>
             clean
             convert gpt
             exit
      • Close Command Prompt, return to Windows Setup.
      • Choose Custom install, select the unallocated space on the SSD, and click Next.
        Windows Setup will create the required partitions and install to the SSD.
    3. Install to SSD as a standard internal drive
      The SSD is treated like any other internal hard drive:
      • Ensure the SSD has sufficient capacity (minimum 16 GB, realistically much more).
      • Boot Windows Setup from USB/DVD/ISO.
      • Select the SSD in the Where do you want to install Windows? screen.
      • If multiple drives are present, verify the correct disk before deleting or creating partitions.
    4. Advanced scenarios (VHD/VHDX boot)
      For scenarios where Windows is installed into a VHD/VHDX and then added to the boot menu:
      • Prepare the VHD/VHDX and apply a Windows image to it.
      • Use bcdboot from WinPE or an existing Windows installation to add a boot entry pointing at that Windows instance.
        This is documented for native boot to VHD, not specifically for launching Setup from a local WIM.
    The documentation in context does not describe or endorse using third‑party tools (such as EasyBCD) to create a temporary boot entry that launches boot.wim directly from a local partition for installation. The supported path is to run Windows Setup as a bootable program from:
    • USB key
    • DVD
    • Mounted ISO
    • Network device
    Once Windows Setup is booted by one of these supported methods, installing to an SSD is fully supported, including wiping, repartitioning, and converting the SSD to GPT if needed.
